RS2 rear tie rod trick.
  • rs2315
    • Jun 2006
    • 867
    Originally posted by madpugger
    Congrats on the second baby
    Ta,
    rs2315.
    • Evilgoat76
      • Feb 2010
      • 278
      • Home: Canada Current: United Kingdom
      Had the same on the zuki, G-clamp worked a treat. I have one with a split lower jaw that means you can get a spaniard in there.
      • rs2315
        • Jun 2006
        • 867
        Pleased to anounce jobs a good un
        Trolley jack worked a treat. Just popped a bit of rubber on saddle to protect shiny new tie rod.
        Just made sure saddle was well located, then applyed a bit of pressure.
        Nut went on so far then spindle started to move again, so added a bit more pressure and that was enough to hold spindle, so both sides are nice and tight now
        Thanks for all the advice from you chaps, hope this thread might help someone else doing the same job.
        rs2315.
