How long should batteries last???
  • Fat Audi 80
    • 10547
    Well I the last new battery in the S2 has lasted about 4-5 years, which I though was okay considering I run it down completely flat in the garage on numerous occasions.
    Yesterday I went to Anna's Audi 80. It was flat as a pancake and had been driven on Thursday with no problems.
    I would not jump start off another car, so I put my Ctek charger on it. It has now been charging for nearly 24 hours and the battery is showing 10v!
    The battery is 3.5 years old (warranty was for 3 years ) so my question is, does that seem normal? I though batteries normally lasted 5 - 10 years?
    I don't think this one has ever been run particularly flat, although for the last year to nine months the car has only been used once a week or so for shortish trips. Would that kill a battery stone dead???
    Bear in mind the car has never not started since we bought the battery....
    Any comments?
    Cheers,
    Steve
    The Perfectionist
  • Rusty
    • 18953
    If it's that dead then it sounds like you might have a short, perhaps an ageing alarm or dodgy boot light?
    • ryster
      • Sep 2007
      • 224
      mine lasted just over 18 months luckly was with the warranty and they had it back on friday
      • Fat Audi 80
        • 10547
        Agreed, I am worried there is something wrong that has caused this sudden failure...
        The Perfectionist
          I would recon 4-5 year life for a decent quality battery. Has it got enough fluid in it Steve?
          • ryster
            • Sep 2007
            • 224
            i thought it was my cd player or boot light or some thing . we 'll see if the same happens to this battery . i hope its not a short as i don't now where to start finding that. the battery brfore the last one lasted years untill the cold had it .
            • Fat Audi 80
              • 10547
              It is a sealed unit IIRC... (Will check)
              The Perfectionist
              • SteveH
                • 4460
                If it's a calcium technology battery they can go funny really quickly with no warning. I had one go on my car recently, it had never shown any signs of failure like sluggish cranking and went completely flat overnight a few weeks back. I drive thousands of miles each month, so I thought I must have left the lights on. After a few hours charging it started the car, so I left home and did 400 miles the same day. Parked it up in th evening and it was completely flat in the morning. Changed the battery and all is well again. The old lead acid units were a little more predicatable than the latest sealed units.
                91 Modded 3B
                14 A6 Avant Black Edition
                • denniselbows
                  • 740
                  batterys can fail at anytime weather a month old or ten years old. if the top of the battery is dirty it can loose power due to voltage tracking across between cells. i came across one not so long ago that the current leaking across burnt the top of the battery away. also if a battery is left disscharged the plates in side can start to sulpha up with in a week and that will shorten its life even if you manage to charge it up again the sg will not get as high as it was before discharging. put a amp meter in between the positive terminal of the battery and the terminal that goes to it and see how many amps are being drawn and that will determin if you have something draining the battery
                  never set your expectations to high that way you are never disapointed
                  • denniselbows
                    • 740
                    the lead acid batterys that come on the nissan forklifts i work on are very unpredicatable the driver can start them up fine then stop it sometime later say going for his break when he goes to start it again bang nothing click click click flat battery. when you test them they have a good 13 volts in them turn the key it drops straight away to nothing new battery needed. i come across this at least 10 times a year, must be a fault that is common in that make of battery, by the way they are a tudor make so stay clear, so the lead acid ones are just as unpredicatable.
                    • johne
                      • Apr 2007
                      • 1405
                      Steve, from what I've read and based on my own experience, battery life can be very variable & batteries with 2 or 3 year g'tees often only make close to that.
                      In this case I think you've lost one cell short-circuit, hence the 10 volts reading and there's nothing you can do about it.
                      If you think you're going to keep Anna's car it's worth buying a replacement battery from a reputable make like Varta or Bosch.
                      John
                      • Fat Audi 80
                        • 10547
                        Thanks chaps.
                        I will chuck another battery in it this week and go from there. (About £60 for a reasonable one)
                        The Perfectionist
                          I've always used Varta batteries, good money and 5 year warranty on the higher end ones
                          Try Tayna Batteries, good prices and service
                          • Fat Audi 80
                            • 10547
                            Cheers Alex.
                            The Perfectionist
                              Old thread resurrection. I went out to start the s2 at weekend and do a couple of bits but the battery has had it. What would people recommend now? Do batteries have a lifetime warranty theses days?
                              I had a quick look on Tanya the enduroline one looked as good as any with a 4 year warranty. https://www.tayna.co.uk/096-Enduroli...ery-P8383.html
                              Or
                              E44 VARTA Dynamic SLI Car Battery Innovation with Purpose, Premium Experience, Powerful History VARTA was founded in 1887 Germany, and was established fully in 1904 by delivering the first electric vehicle battery, famously driven by Thomas Edison. Soon after, VARTA delivers the first ever vehicle battery to provide safe night time driving with electric vehicle headlights! Today’s VARTA batteries have been providing renowned German advanced technology, powerful performance and exceptional service around the world for well over 100 years. VARTA Dynamic SLI is the perfect choice for non-start-stop technology with the highest power needs. It offers supreme starting power that will meet the toughest energy demands without compromise. This VARTA Dynamic SLI has an impressive five year guarantee to ensure ultimate peace of mind for years to come. Dynamic SLI Key Benefits • Engineered to the highest German standards • Patented PowerFrame® grid for reliable starting power, fast recharge and corrosion resistance. • Like-for-like replacement of OE batteries (Original Equipment) • The premium battery for vehicles with non-start-stop technology • Recyclable and produced in an energy-saving way Maintenance Free Other References 096, Varta DIN: 577 400 078, Silver Dynamic 5 Year Warranty *Always cross reference dimensions and specifications to your existing battery or application before ordering.
                              EA770 Exide Premium Car Battery 067TE Exide are one of the leading battery manufacturers companies in the world and have been delivering quality in the automotive and infrastructure sectors for more than 130 years! Exide premium car batteries are Exide's leading wet lead acid battery range. They are boosted by carbon additives that are added to the plates which result in the batteries recharging up to 1.5 times faster. They are up to 30% more powerful than equivalent batteries and are ideal for powerful cars with some electrical demand. These batteries can withstand all weather conditions due to Exide's premium build quality. This comprehensive range covers around 90% of UK cars and meets OE requirements.
