whirring noise in cabin, by left foot
  • willg54
    • Jun 2009
    • 2055
    I have an intermittent whirring noise down by my left foot when the engine is running. Quite hard to describe. It's there most the time but stops for a few seconds sometimes. Can't find it being linked to anything, nothing seems to start or stop it.
    Any ideas?
    If not ill start pulling bits off to find out!
    Will
  • K Simmonds
    • Dec 2007
    • 7627
    Does it sound like the source of the noise is in or outside your car?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • willg54
      • Jun 2009
      • 2055
      Sounds inside, towards the centre console but not entirely sure. Doesn't seem like the frequency of the noise increases with rpm or anything.
      • Rusty
        • 18953
        Sure it's not just the fuel pump They can be quite noisy, especially if you've no interior
        • willg54
          • Jun 2009
          • 2055
          Defo not fuel pump unless its under the dash Haha. It sometimes goes for few seconds then comes back.
          • s20ale
            • Aug 2004
            • 476
            I had a window relay create a buzzing sort of noise, may be worth a look/listen.
            • s2driveruk
              • 12696
              yep have something similar, never got to the bottom of it but having said that nothing stoppd working either
              1992 3b S2 Coupe
              • willg54
                • Jun 2009
                • 2055
                right....it sounds like its related to the steering. when i was sat at the lights i realised if i slightly turned the wheel the noise stops!! only happens when im driving in a straight line with no steering input!
                sounds like static from a speaker or air bubbling under pressure through a pipe....
                • s2driveruk
                  • 12696
                  check you havent dislodged the rubber boot which is on the end of the column going through the firewall...? Definately hear a bit more of anything if thats open and probably a small draft too
                  1992 3b S2 Coupe
                  • willg54
                    • Jun 2009
                    • 2055
                    whats the easiest way of seeing/getting to said bung? driving to uni on tuesday so can get on the ramps too! oh the luxuries oh being 'in' with the lab staff!
                    • s2driveruk
                      • 12696
                      stuck your head in the footwell, follow the column down and you'll see it, its a pretty big bung and should push back into place...
                      1992 3b S2 Coupe
                      • Dan
                        • Jun 2008
                        • 1242
                        ...perferably not while driving, one might add.
                        1993 ABY Coupe | BMW R1200 GS
                        A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
                        • s2driveruk
                          • 12696
                          if you can get your head down there while driving you should be in the circus....i'd pay to see that
                          1992 3b S2 Coupe
                          • willg54
                            • Jun 2009
                            • 2055
                            haha im defo not a 'carnie'...ill try it parked up first! cheers, i'll let you know if this silences it! doesnt feel like the steering is struggling or leaking anywhere that i know of!
                            • 5banger
                              • Aug 2009
                              • 19
                              not abs pump? is on that side.
