Headlight bulbs
  • Christophski
    • 3632
    Headlight bulbs
    Hey guys
    Can anyone tell me what headlight bulb (ie h1/ h4 etc) I need for the main beam in my s2.(the middle bulb in the unit) They are non ellipsoid headlights.
    Thanks
    Chris
  • s2driveruk
    • 12696
    they are H4 as the dipped and full beam are off a single bulb from memory. I've just ordered a set of phillips xtreme 100percent in a H1 for my A6 as they did well in a recent buld review...might be a good bet
    1992 3b S2 Coupe
      Yeah phillips extreme are really good, H4 dual filament for the dip/head and H1 for the mains. IIRC
      • Christophski
        • 3632
        Cool cheers. Just gotta find some White bulbs for them then and then some White bulbs for the side lights. I found the high beam ones for £1! The White bulbs will hopefully help make the headlights a bit better.
          • Christophski
            • 3632
            Nice one. Cheers newsh
            • s2driveruk
              • 12696
              jus back from installing mine philips x-treme 100% H1's on the A6...the difference is quite staggering, especially sign and general reflective response of objects in the distance. I can actualy see my beam pattern still when people pass which was impossible previously so a definate thumbs up from me.
              Genuinely worth the £29 i paid for them and a must for anyone on ellipsoids who has yet to convert them to xenons.
              1992 3b S2 Coupe
              • Christophski
                • 3632
                I dont have ellipsoids and all im changing is the bulbs. I dont have to do anything else to make these work do I?
                I assumed it was just plug n play with the bulbs.
                  Just plug and play with either normal or elipsoids, nicer light than HIDs too IMHO
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Never used the Philips but i've used the Osram versions, much whiter light from them and a noticeable improvement in range. I was sceptical at first but they do work much better.
                    For projector lights you really need HIDS to have any hope of seeing where your going on dipped beam.
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                    • s2driveruk
                      • 12696
                      i think these are a good compromise on needing to go to a full HID kit to be honest. light output is good, colour is not as white as a HID but it's a definate improvement over stock bulbs...
                      Agree, once you've had HID's, you actually wonder how you really saw anything before
                      1992 3b S2 Coupe
                      • Christophski
                        • 3632
                        Well when my bulbs arrive hopefully Friday I will be on a mission to fit em n hopefully I will be able to see where I'm going! Will be the first time in 4 years!
