Suspension Woes!!
  • blues n 2s
    • Jun 2008
    • 136
    Suspension Woes!!
    Advice Pls Guys.got A 7a Cq With 3b An 7a Standard Suspension.have Just Swerved To Miss A Stupid Teen An Whacked Kerb.trackin Now Way Out So Much So Guy Reckons Somethin Is Bent.visibly All Looks Ok Except Mis Alignment Can Be Seen.thinkin Of Replacing Strut & Wishbone.should I Look For Anything Else?? Also Thinking Replace Top Mountsx2 So Should I Upgrade Parts With Maybe Aby Bits Inc Shocks & Springs.thinking Of Cost Would It Make More Sense To Do Whole Lot Now Seeing As Work Is Needed.recomendations For Upgrade Be Appreciated Guys & Offers For Parts.
    I must have an S2!!!!
  • djh
    • Jun 2011
    • 1622
    i'd say either lower wishbone or steering track rod/arm most likely. Doubt the strut would be that bad. If its either of those bits I have some spare
    • blues n 2s
      • Jun 2008
      • 136
      THAT WHAT YOU RECOMMEND AS STARTING POINT? DID HIT HIGH KERB PRETTY HARD.SHOULD OF JUST HIT HIM. ****** JUST CARRIED ON RUNNING.HOW MUCH FOR BITS MATE?CHEERS MARK
      • Rusty
        • 18953
        More than likely, you've pushed the lower balljoint into the lower arm - this is a 'safety' feature to stop you bending the lower arm. Replace the nylocks and torque to 65Nm when all done; it's a lot but it's what the book says. Get it to a proper 4 wheel alignment place and get them to re-set the camber.
        I did the same thing 18 months ago in the snow and it was easily rectified for £50 at my chosen place.
        ABY springs will fit straight on or you can fit 3B springs and dampers. ABY front dampers won't fit, as they're a larger OD but rears are the same. Fit them at the same time as fitting new top mounts. Secondhand stuff will be cheap; new stuff will last longer. I'd say get a set of uprated dampers and stock springs for daily use.
        As an aside, please don't write in capitals; it's seen as shouting and is a lot harder to read than normal sentence case - it may mean that you don't get as many people reading your posts and thus miss out on some vital information
        • blues n 2s
          • Jun 2008
          • 136
          OK cheers rusty thanks for advice.Will do that.Sorry for writing in capitals it easier for me as i slow enough without having to use caps lock haha
