Advice Pls Guys.got A 7a Cq With 3b An 7a Standard Suspension.have Just Swerved To Miss A Stupid Teen An Whacked Kerb.trackin Now Way Out So Much So Guy Reckons Somethin Is Bent.visibly All Looks Ok Except Mis Alignment Can Be Seen.thinkin Of Replacing Strut & Wishbone.should I Look For Anything Else?? Also Thinking Replace Top Mountsx2 So Should I Upgrade Parts With Maybe Aby Bits Inc Shocks & Springs.thinking Of Cost Would It Make More Sense To Do Whole Lot Now Seeing As Work Is Needed.recomendations For Upgrade Be Appreciated Guys & Offers For Parts.
Suspension Woes!!
Tags: None
THAT WHAT YOU RECOMMEND AS STARTING POINT? DID HIT HIGH KERB PRETTY HARD.SHOULD OF JUST HIT HIM. ****** JUST CARRIED ON RUNNING.HOW MUCH FOR BITS MATE?CHEERS MARKI must have an S2!!!!Comment
More than likely, you've pushed the lower balljoint into the lower arm - this is a 'safety' feature to stop you bending the lower arm. Replace the nylocks and torque to 65Nm when all done; it's a lot but it's what the book says. Get it to a proper 4 wheel alignment place and get them to re-set the camber.
I did the same thing 18 months ago in the snow and it was easily rectified for £50 at my chosen place.
ABY springs will fit straight on or you can fit 3B springs and dampers. ABY front dampers won't fit, as they're a larger OD but rears are the same. Fit them at the same time as fitting new top mounts. Secondhand stuff will be cheap; new stuff will last longer. I'd say get a set of uprated dampers and stock springs for daily use.
As an aside, please don't write in capitals; it's seen as shouting and is a lot harder to read than normal sentence case - it may mean that you don't get as many people reading your posts and thus miss out on some vital information
OK cheers rusty thanks for advice.Will do that.Sorry for writing in capitals it easier for me as i slow enough without having to use caps lock hahaMore than likely, you've pushed the lower balljoint into the lower arm - this is a 'safety' feature to stop you bending the lower arm. Replace the nylocks and torque to 65Nm when all done; it's a lot but it's what the book says. Get it to a proper 4 wheel alignment place and get them to re-set the camber.
