Coolant leak- oil cooler?
  • Christophski
    • 3632
    Hey guys found the leak at last when I did the oil change. Basically I'm losing coolant and it's spraying the oil filter. It's from the unions. Is this the pipes for the oil cooler? Or is it pipes for something else? Anyone any ideas?
    Chris
    Probably the turbo coolant pipes, the oil cooler has no water connection.
    • Christophski
      • 3632
      Aha, cool cheers bud. New pipes onto the list then. Anyone got any?
      • mcandmar
        • Apr 2004
        • 5118
        Both water lines to the turbo are metal and pricey. I have seen the lower one leak that connects to the core plug in the block under the exhaust manifold, i would check there first.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • willg54
          • Jun 2009
          • 2055
          might be just a seal, dont rush into just replacing the hoses!
          1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
          1994 Audi 80 - 2.0 8v (slow but reliable!)
          • Christophski
            • 3632
            So these pipes have seals??? How do I check if its the seals? And its definately from that area as there is dry ish crust around the edges of the pipe. Thing is I cant remember which one it is as I saw it a month or so ago when I was under there and have been busy trying to sort out other things and work atm.
              As above, the only water lines in that area are for the turbo. The other thing to check, is the hose running from the water manifold to the turbo feed pipe - this can get in a terrible sate, leak and could run around the pipe to the area described.
