Have spent a few hours today trying to remove the glass sunroof panel from my Coupe so I can replace the seal, but I am not getting anywhere !!
As far as I can see, I need to remove 3 screws each side so I can lift the panel clear of the operating mechanism.
Trouble is, when roof is tilted, I cant get to the forward one on each side as there is a black plastic trim which obscures the screw head.
The trim is secured to the glass roof panel with a couple of screws which I have also removed in case I could slide the trim backwards into the roof lining to give access to the panel attachments, but although it's now loose, it doesnt want to slide independently of the glass panel.
Can anybody point me in the right direction and explain what I am doing wrong.
Cheers in advance !!
Martin
Martin
