hey guys
So having got my car all back together and running ok for a few months now I think I have a boost leak but I just need some guidance on if it could be something else that springs to the minds of some of you more in the know.
The car is a homefried ABY with all Samco boost hoses and all of the vac hoses done in Poly too so none of these should be split anywhere (some of them only done last December) and it has the Mark H mod too.
Obviously I will check all the hoses for splits anyway and need to run a leak test, but i just want to know if it sounds like any other common issue? I will also just nip all the hose clamps up a bit in case its that simple
Basically if i floor it Sometimes I only reach 1 bar boost sometimes not even that but if I ease off slightly and floor it again in the same run as it were it will boost a bit higher and then fall a bit. Does this soudn like boost leak or something else I need to investigate. I dont get the big boost cut thing like its breaking all of a sudden. It runs and idles fine....
Also, I do have a leak test kit but the bung with the nipple on it is way to small for the MAF hose for some reason. Does anyone have one I could borrow to pressurise the system please?
Cheers in advance.
Cheers in advance.
