Urgent help Required Please
  • anthonys2
    • 3512
    Guys am a little lost with this problem and its bloody annoying considering am in Germany near Trier and feel theres fxxk all I can do at the moment!! The central locking/alarm is playing up from my key fob on the S2 (yes brave enough to take it on the continent!!) and now the key fob playing up whats helped in the last few days is discontenting the battery completely for 5 minutes and then everything works as it should but now that's not happening and when I connect everything back up the bloody alarm is just going off all the time - Any suggestions what I can do as a quick fix until I get back into the UK please - kind of panicking at the moment as the car is isn't fully locked and in the morning it wont be driveable MANY thanks in advance
  • S2TORNADO
    • Jan 2008
    • 620
    Have you got a little round key on your fob. It's usually around say 8mm in diameter with a small drive tang. It's often possible to turn off the audio part of the alarm at the box, (usually under the bonnet).
    You might be able to use something other than the key as they're usually fairy basic.
    • anthonys2
      • 3512
      Naa its just 2 buttons on the fob the bottom one never gets used and the top button opens and locks but now doing neither theres still power as the light is flashing on the fob when I press the button but its now 13 years old this piece of kit is there anything I can do with the fuse box?
        Is it OEM?
        Just cost the light flashes on the fob, doesn't mean its working properly. First thing I'd do is change the battery in the fob
        Worst case cut the power to the siren, wait for the battery to run out and unlock manually.
        • anthonys2
          • 3512
          Its after market cat 1 alarm I got it put on nearly 14 years ago so its a bit old whats worked in the last day or so is I can open the car with key in the door disconnect battery for 5 minutes or so connect back up the central locking then works and alarm is fine now I have the battery disconnected as soon as I go to connect the battery the alarm is going off so at the moment the battery is disconnected otherwise the alarm would be going off this is the one bloody thing I didn't account for I do have European cover from the AA so looks like I will be phoning them in the morning now
          • S2TORNADO
            • Jan 2008
            • 620
            Are you saying the alarm sounds but the car runs without cutting out OR the alarm sounds and the car won't run?
            The audio can be turned off for most alarms. If you find the box there's a good chance you'll find the little key hole.
            • anthonys2
              • 3512
              sorry Andy I didn't try either as there were a restaurant full of people staring at me lol!! All I know at the moment is the alarm will sound as soon as I connect the battery back up so I have left it disconnected and will try again in the morning
                You will be able to unplug the siren from the alarm/immob harness. Do that first to shut the thing up. Then reconnect the battery and see if you can start the car. If the worst comes to the worst, its actually really easy to remove a Cat1
                At the very least, you only need some cable cutters and some tape. Ideally butt crimps though.
                Seriously though, I would try a new battery in the fob first of all.
                • anthonys2
                  • 3512
                  Cheers fellas!! The missus is saying I told you to take the A4!! And il call the AA in the morning as well as I want to continue my holiday and not cut short
                  • Monkeymagic
                    • Mar 2012
                    • 3419
                    i Had this with my Clifford Alarm it was the back up battery in the siren dying and leaking into the internals. I just cut the cable until I could get a new siren.
                    • anthonys2
                      • 3512
                      If I cut the cable to the siren that would solve the noise but what about the immobiliser would that not be affected?
                        As Error has said, get a new battery into your fob. The existing battery when it is on it's last legs, will still have enough power to light the led, but not have enough power to turn off the alarm. Try pressing the remote when it is very close to the box / brain that controls the alarm as it might turn it off when it is closer and it's transmission range is reduced because of the failing battery in the remote.
                        But really you need to get a new battery for the remote before you cut any wires to the siren, or phone the AA.
                        If your luck is in, a new battery for the remote control unit could solve the issue. You'll never know until you get one !
                        Best of luck.
                        • Sonic
                          • Jul 2006
                          • 5514
                          First off shut the siren up by disconnecting it - this means you can play with the thing for as long as you want and not get stressed out whilst pissing everyone else off!
                          Next see if the car starts even with the alarm going off, this will give you an indication as to where the problem lies and mean you're not stranded worst case scenario!
                          If the car doesn't start it'll be the immobiliser so try replacing the battery.
                          If it does start it'll be the stock alarm playing up which is common on mine. With the alarm going off put the key in the door and lock it which should engage the central locking, then unlock. I find this sometimes takes a few goes turning the key all the way to the right to get it to work.
                          S2Forum.com Administrator
                          • anthonys2
                            • 3512
                            Thanks guys for the advice I will try this in the morning
                            Once again when theres a problem you can always count on the support of others on this brilliant forum
                            • anthonys2
                              • 3512
                              Right the time has come I tried the alarm this morning disconnected the unit was going to cut the wire but bloody hell there were a **** load of wires so didn't however opening the unit up there are 2 medium size fattish batteries never seen the size before one is heavily corroded so going to see if I can get this swapped and renew key fob batteries wish me luck lol!!!
