Fault codes grrrr!
  • andyg plym
    • Nov 2006
    • 4646
    Fault codes grrrr!
    Well I have to say apart from a few little bits n bobs my s2 has been running beautifully.
    Obviously, it's a question of when not if you start having problems as we all know.
    So running on ts chips and rs2 turbo and pulling hard to 1.7 bar, I decided that this wasn't enough as it should be 1.9. Did a boost leak test and no leaks I changed the spring on the forge recirc and get to 1.8 but then started getting a misfire under load intermittently.
    I changed back to the green spring from blue and expected it to be ok, still misfiring
    I'm thinking boost leak as the maf hose is original and it got pulled about whilst playing with the forge.
    Decided to vag com it and got 00561 mixture adaption, looked into possible causes and decided I'd probably got a boost leak so today I swapped the hose for a samco.
    Also replaced the lambda for a newer one as it could of been a cause and I had a spare -went for a blast, again misfire under load, you can drive through it and still hit 1.7 bar (as it used to be) it's not boost cut, seems ignition related to me.
    Got home and pulled the 00537 lambda regulation control limit surpassed.
    What are we thinking peeps ? Spark plugs a few months old, it's odd how you can drive through it
    Do ignition amplifiers /coils show up on vag com ?
  • andyg plym
    • Nov 2006
    • 4646
    Looking into it amplifiers would also show problems on idle, mine is sweet so I'm looking more to coil packs nowg
      Improved POS diagnostic and fix info
      Have a read on this:
      And this ("One missing and hesitation diagnostic"):
      • andyg plym
        • Nov 2006
        • 4646
        Dave cheers
        That's what I read and came to the assumption about coil packs.
        I'm going to check them first, it idles sweet so I doubt it's the pos units.
        I'm hoping it's not fuel pressure related as that seems to be a symptom that comes up on all codes, it's got a new 044 pump but still not fitted a non return valve.
        I was thinking this could be related to pressure as I went away for a week and came back and it struggled to start due to no fuel in the lines. Starts fine now though
        • andyg plym
          • Nov 2006
          • 4646
          Guys any thoughts on this? Switched to 1.8t coilpacks and done away with the pos units now and last night did a boost leak test with no leaks.
          00537 control limit surpassed 8-00
          Lambda ??
          • mike74
            • Apr 2014
            • 615
            Try putting the old lambda back in and see if it makes nay difference. The one that's in might be a duffer
            • quattro-nick
              • Sep 2012
              • 1746
              • Country: Belgium
              maybe you can check fuel pressure on idle and under high boost
              TWINCHARGED power,zero lag
              AEM W/M injection
                And how is that easily done?
                  With a 044 pump and proper fuel lines (no kinks) you should have no lack of fuel pressure. However, if your fuel pressure regulator is not up to the new flow or you have a tear in the diaphragm, there might be an issue.
                  No non-return check valve = harder on your starter due to longer cranking times since the fuel pump is NOT energized with just the key turned to ON. It needs at least 13 RPM to trigger the ECU to energize the fuel pump relay (which in turn energizes the fuel pump).
                  Click on the appropriate labels in this live map:
                  • andyg plym
                    • Nov 2006
                    • 4646
                    Did quite a but of homework on the non return valve but at that time was desparate to fit the new fuel pump and I have to say it's not as bad as I'd thought.
                    Yes as expected occasionally it takes a bit more cranking over but most of the time it starts on the key.
                    I may have to have a look at the fpr as it's one thing I've never replaced
                    • quattro-nick
                      • Sep 2012
                      • 1746
                      • Country: Belgium
                      @ urs4boy
                      just connect a mechanical fuelpressure gauge on the pressure side of the fuelrail.you can do this by use a longer banjo bolt and put a second banjo eye(dont know how it calls) on it,i made my fuelpressure gauge like this on the engine
                      if you take a long fuel hose you can mount the gauge against the window so you can see the pressure while driving
                      AEM W/M injection
                        just connect a mechanical fuelpressure gauge on the pressure side of the fuelrail.you can do this by use a longer banjo bolt and put a second banjo eye(dont know how it calls) on it,i made my fuelpressure gauge like this on the engine if you take a long fuel hose you can mount the gauge against the window so you can see the pressure while driving
                        Photos?
                        PS: That might work on an UrS4 but it will NOT work on an UrS6 because there is no banjo bolt at the fuel rail (it's a silver-soldered fitting/connection).
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          if you want, I will take a picture of it
                          i have a AAN engine with AAN fuelrail
                          AEM W/M injection
                            Please. Your fuel rail must be from an UrS4 (which is what I have) so I would like to see what you did.
                            • quattro-nick
                              • Sep 2012
                              • 1746
                              • Country: Belgium
                              yes,engine come from urs4 donor car
                              pictures of my fuelpressure gauge and adjustable fuelpressure regulator
                              AEM W/M injection
