I had a the top rad hose goes , so I replaced with silicon hoses. Top water up and bleed system . Got it up to temperature , fan came on ! took it out for a test run temp. Went. Down. To about 70 degrees ( it was very cold that day mind ) then had temp symbol. Flashing. Up on dash and bleeping , so. I replaced. Mfts. Now. Symbol and beeping has gone. But but the temp sensor. Is ready. About. 105/110 degrees. And the fan has not come on. I Checked fuse for fan. Car doesn't seem like it is over heating but don't want to risk it.
Is the a test I can do to find out the problem any help with this. Would be great
Regard. Ryan
Regard. Ryan
