So guys whos running nitrous if so/if not what are peoples thoughts abput it also what would i have to do if i wanted to put a kit on a standard engine and what bhp kit could i go up to being safe (just enquiring not sure if i want to do this or not yet)
Thoughts/infor on nitrous
Tags: None
Either I'm completely loosing it or dreamt it but I can vaguely recall Andy10V mentioning nitrous, not sure if he had it fitted or not though, however I'm sure there's a couple of other members on here running it.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
Nitrous
Jamie my mates uncle own nitrous in doncaster I had a wet kit on golf 1.8t but it was killing my turbos I think by time I got kit controller bottle warmer I spent £1200+ running on 100bhp jets you can go more but I don't no how rods would cope on standard blockComment
I fitted a wet nitrous setup for a giggle, start with small nozzles and get the AFR right, then increase the jet sizes.
A progressive controller would be best, especially if you are going to add a lot of power, I just had it on a switch (rear wiper) and only used it at WOT above 3000rpm as a safe guesstimate. T into the fuel feed line, fogger went into the TB hose.
Good fun, makes the car pull like mad! Obviously catastrophic if you get it wrong, "danger to the manifold style".
Also drops IAT.
Its good fun if you can do it cheap, cost me £180 plus a bottle fill for a second hand kit, at £1200 I would just spend £1500 and RS2 it.
I need to get mine back, Martinws was trying it on his ABY 90 but it did not work well, I assume as a 3b is 3bar and aby is 4 bar it was mega rich.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
Cheers for input guys was thinking running nitrous with stock engine BUT i will but running 650 ish brake at later date so im thinking getting rods pistons and bottom end bearings soon as possible and fitting them soon as so its all out the way of anyone knows a good place or has any of these items? Prefer them balanced 81.5mm is correct stock bore if im not mistaken? ?Comment
