Hi guys need your help I posted recently about no boost ,I have done a boost leak test and no leaks even using soapy water ,I have taken all the hose,s off from MAF sensor right through to the throttle body ,inspected for any splits none, I have tested from MAF to the hose out of the intercooler no leaks, the engine runs sweet ,one thing I did notice is I have a vacuum/boost gauge and I have massive vacuum when you drive up to 2000 rpm anything above that it's guttless, I have no missfire it starts first time ,it ticks over fine just no DAMM boost
