Cab FARB fit on rear of s2 coupe ?
  • Gazmitchell
    • Feb 2013
    • 640
    As above are these the same and do they fit ? Thanks
    Should do. Needs to be the later B4 bar that has drop links. Measure the diameter, it'll be 24mm or 25mm, like mine.
    • Gazmitchell
      • Feb 2013
      • 640
      Cheers Andy , just there's one on ebay so didn't wanna go after it if no good .
        If it's the 2.8 cab one, that'll work
        • sam80quattro
          • Oct 2006
          • 1496
          Can't you use a early b3 anti roll bar with the short bent links into the bottom arms?
          • dubmanted
            • Jun 2014
            • 312
            I have a 2.8 cab FARB here attached to a good subframe
            • GazzaG60
              • 4133
              i got a 16v Quattro front bar here. its basically same as s2 bar.
                It's all covered here http://www.s2forum.com/forum/showthread.php?t=20175
                • Gazmitchell
                  • Feb 2013
                  • 640
                  It's an 1.8 cab one ... ? Only paid £20 for it but didn't wanna spend loads on Rarb if I can help it as the rear subframe swap job is expanding as I go lol .. Now inc fuel lines it'll be a an underbody resto and paint the way it's going !!!
