Wtf !? What am I missing ?!
  • Gazmitchell
    • Feb 2013
    • 640
    So new subframe done bushes in up and bolted up. Wishbones on , new lemforder rear tie rods are too long fully wound back ? What the ? ! I measured them against ones I removed to get approx length right and had to wind em fully back and still makes rear wheels toe in any ideas ? I didn't remove driveshafts and hubs either . Just rear struts and subframe overhaul.
  • andy10v
    • 5996
    Have the ball joints slid in on the wishbones?
    I take it they are the correct tie rods?
    Sold ABY-stock
    • Gazmitchell
      • Feb 2013
      • 640
      Andy , no they hadn't moved and bought the rods off the chap on here . Even undid the ball joint to get max movement outwards ... I measured new ones against rusty old ones to get correct height so well strange .?
      • andy10v
        • 5996
        Is it the same subframe with new bushes or a refurbished subframe?
        If it is another subframe it could be from a another quattro car with different length tie rods and slightly different tie rod mount location on the subframe.
        Sold ABY-stock
        • ajax1976
          • Aug 2015
          • 212
          Wishbones back on the same sides they came off?
          • Gazmitchell
            • Feb 2013
            • 640
            It is a diff subframe yes, a 3b with no arb brackets , I removed my ones from old subframe and re welded , but I thought the tie rod mounts were in same place .? I re welded arb brackets over tie rod mounts .. Have I answered my own question !!?
            • Mikes2
              • 1704
              Different track rods are used on cars with no rear anti roll bar because the brackets are in different places
              Mike
              http://www.s2-audi.co.uk
              • Gazmitchell
                • Feb 2013
                • 640
                Ah . Shyte dam and darn ! and I was going so well !!
                • SteveH
                  • 4460
                  The 3B subframe has arb brackets, so your replacement isn't from a 3B. Probably from a UR??
                  91 Modded 3B
                  14 A6 Avant Black Edition
                    Or early 10v B3 car
                    • Pauliusb2
                      • Dec 2014
                      • 361
                      you should put your subframe on your old one and see how far out is your brackets on original subframe.
                        Swap the tie rod for the early type
                        • Pauliusb2
                          • Dec 2014
                          • 361
                          I think he needs early type tie rods or reweld location...
                          • Gazmitchell
                            • Feb 2013
                            • 640
                            Cheers for the help all. Looks like I've a brand new set of lemforder for sale then with a nice fresh coat of POR15
                            Where can I get early ones - are they the longer body smaller arched ones .?
                            The subframe is a B3 as said. Just checked.
                            • Mikes2
                              • 1704
                              Sounds like you want LEMFÖRDER - Ref: 10051 01
                              Mike
