ABS Sensors
  • Martin62
    • Jan 2011
    • 187
    ABS Sensors
    I'm currently refurbing the rear subframe, hubs, driveshafts etc on my 7A quattro coupe and you won't be surprised to hear that I have destroyed the ABS sensors getting them out !!
    I know I can use front sensors, splicing them in to the longer rear cables but I was wondering if any of the sensors from later Audi / VW cars will work.
    I notice that the sensor 8D0927803 looks very similar with the exception of the connector. I think it's from early A4 and Passat models
    Unfortunately I haven't found any info on dimensions or resistance values etc that will give me a view one way or the other.
    Has anyone tried these or does anyone know for definite that they will or will not work ?
    They are very cheap on ebay so if not I will get some and try them.
    Cheers,
    Martin
  • Mikes2
    • 1704
    It's an A4 rear I used. Just changed the connector and spliced in some extra wire
    Mike
    http://www.s2-audi.co.uk
    • Martin62
      • Jan 2011
      • 187
      Cheers Mike,
      I will do the same.
      Martin
