Will an MOT brake testing machine (freinometer?) always ruin the centre diff?
  • LHD_Kid
    • May 2006
    • 3697
    Despite my very strict instructions and almost begging them not to, the stupid people at the Belgian department of transport insisted on putting my S2 on the brake rollers... front and rear wheels...
    I now have a strange noise which wasn't there yesterday, kind of like wind rush, but coming from the centre diff area of the car - happens on lift-off and not when driving really slowly... does happen in more than one gear...
  • Mikes2
    • 1704
    If the speed is kept low enough, it doesn't cause any problems. Seem to remember 4mph being the number
    Mike
    http://www.s2-audi.co.uk
    • irishs2
      • Apr 2009
      • 2455
      From Audi direct for testing on a single-axle brake dynamometer for four-wheel drive vehicles:
      "The Torsen differential will be seriously damaged if test speed exceeds 6 km/h."
      Eric
      95 S2 Avant under rebuild.
      • Rikki Kitto
        • Feb 2010
        • 6276
        Looks like a claim needs putting in bro, my MOT man never puts mine on rollers always takes her out and uses the decelerometer thingy
          • 4754
          Rikkis right.Claim and sue there arses,even after you begged them not too they still went ahead. They deserve what comes there way now the incompetent morons!
          • LHD_Kid
            • May 2006
            • 3697
            Unfortunately, no way to claim as there is no clear evidence they have broken it - they would deny it anyway, after all, the car left the premises under it's own power...
            Remember, this is Belgium, the home of car haters... nothing good ever happens here and especially nothing automotive.
            I'll drive it around for a while and see if it gets worse... if it does, I'll park it as close to the Testers garage as possible and set it alight...
            • Rikki Kitto
              • Feb 2010
              • 6276
              What, like in the entrance close
              • LHD_Kid
                • May 2006
                • 3697
                Yep
                • diesel des
                  • 3896
                  The center diff is easy changed at least. Can be done easy in car.
                  • LHD_Kid
                    • May 2006
                    • 3697
                    Actually Des, that's a really good point... no need to remove the entire box... could be worse...
                    • diesel des
                      • 3896
                      Remove the drive shaft and then its only 5 or 6 bolts. Slides out and new one slides in simples. I have a few if your stuck. I think the center diff should be fairly tolerant to a short run on the break rollers in all fairness. Maybe it's another noise. A few fast starts will help prove one way or the other.
                      • pasbogdan
                        • Sep 2009
                        • 1160
                        • Country: Romania
                        How will a roller damage the torsen?Front wheels on the stand: one turns forward one in reverse.And no action is generated to the center diff.The same with the rear.It just needs the setup for 4x4 car.
                        • LHD_Kid
                          • May 2006
                          • 3697
                          I'm hoping the noise I'm getting is linked to much other prodding and poking around when some fuel lines were changed, perhaps heatshield is touching the gearbox, prop, rear diff.... when under slight load...
                          Going to have a proper look tomorrow, and give it a little stick to test things (now I've got rid of the boost leaks from around the WGFV...)
                          I know it wasn't on the rollers for long and they didn't spin very fast, so... fingers crossed...!
