My car has had the original brake system removed along with the ABS.
I want to reinstate the original brake system but without the ABS.
I have bought a new master brake cylinder and servo and then realized that it was linked to the ABS.
Has anyone took out the ABS and put something else in to replace it.
You need to plumb the L & R front brakes from the front ports on the master cylinder, then plumb the rear circuit off a rear port of the master cylinder. You will need to put a proportioning valve in the rear circuit so you can properly seat up the rear line pressure rate.
