A little Help Required please!
  • anthonys2
    • 3512
    Hi! I just need a little help and a pointer in the right direction please I am dismantling my S2 clocks to replace the lcd time display I have acquired a spare one that works now clocks rev counter etc are out the plastic casing what screws do I need to remove to take the rev counter out please? Many thanks in advance!!!
  • Mikes2
    • 1704
    I did this on a Coupe quattro 20v. I'll see if I can find the pics
    it wasn't that difficult. Scariest part is prising off the needle on the tacho
    Mike
    http://www.s2-audi.co.uk
    • anthonys2
      • 3512
      Cheers Mike was kind of hoping not to take the needle off this would scare the **** out of me!!! Theres 5 brass screws on the back of the rev counter I was wondering if I unscrewed the right ones it would just come away from the plastic unit its attached to?
      • Mikes2
        • 1704
        From another forum
        remove the dimmer (arrowed) and also remove all the screws round the outside - one of them is arrowed. There's 8 of these
        this allows you to remove the circuit board from the glass
        remove the 2 nuts arrowed - this allows you to remove the temp gauge
        the tacho is now removable from the rest of the circuit board. it just lifts up. I used a small screw driver to prise them apart
        the most difficult part - remove the needle from the tacho
        I used small cutlery knives to gently lift the needle from the drive spindle of the tacho.
        Be very careful as it is fragile. I was successful with no breakage. If it was to break, you could probably get away with gluing it
        Once off, you can remove the face by removing the 2 small black screws either side of the needle.
        Also pull off the clock adjuster knob - this requires a bit of force
        Lift off the light guide to allow access to the screws holding the clock
        Mike
        • Mikes2
          • 1704
          Definitely do not try that. I thought you had to go in from the rear as well but you can't. The clock is held on from the front by 2 screws - the only way to get to them is to remove the face
          I've posted some of the pics I took at the time which should help
          Mike
          • anthonys2
            • 3512
            Cheers Mike your a legend mate!! Thanks for the very quick response appreciated
            • Mikes2
              • 1704
              No problem. I need to do it again on my new S2. Clock is totally dead.
              When you refit the needle, be careful to get it in the correct location for sitting at zero. It's counter weighted so when you put the needle on and let it go, it will move to its natural resting position.
              Mike
              • LHD_Kid
                • May 2006
                • 3696
                Best tip I can give, use 2 teaspoons to remove the needle, one each side like 2 little crowbars... very controllable and no sharp edges anywhere!
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  Love this forum, need to pull mine apart, again, to sort the broken cog out in the odometer
