Rs2'ed ABY over fuelling issue
  • Gazmitchell
    • Feb 2013
    • 640
    Hi all
    So finally started car the other day, with new set up and it is blowing black smoke and missing in 2nd gear, -( only gone up and down our drive as front still off the car), revs smooth albeit smokey but it's had new 044 pump new green inj, 3.8 bar FPR , new everything virtually , ABY ecu with new RS2 chips . Any ideas ? I'll plug in code reader tomorrow and see what pops up, only thing I've not changed is plugs - they're fairly new standard ABY ones from old standard set up , should I change ? Cheers
  • Colesy
    • Feb 2009
    • 2980
    Are the injectors the right ones for the chips?
    • Gazmitchell
      • Feb 2013
      • 640
      Hi mate , hmmm they're the light green greens ... ? Id better check with Mr Newsh ..
        The chipset is RS2 and works with stock RS2 injectors
        Check the part numbers, they're on here somewhere
        The ECU ran perfectly on my car with RS2 turbo, RS2 injectors and 3.8bar fpr
          Check for air leaks
          • Gazmitchell
            • Feb 2013
            • 640
            Cheers John, will do.. Yeah I remember when I was after injectors paul Nugent said the light greens were fine .... For his homefries set up, so maybe these have a diff flow rate to stock dark green rs2 ones.. I'll try n suss it.. I'm just glad it actually started !! With all the work and changes I've done lol and there's no air leaks for sure it's had a complete new set of hoses all round and is tight as a drum.
            • Gazmitchell
              • Feb 2013
              • 640
              So looking on past sticky re the two light and dark green injectors it seems the light ones are indeed a slightly higher flow rate than the darks. So hopefully this will explain it John. Cheers
              • bernsaudi
                • Feb 2007
                • 592
                I've had a dodgy 02 sensor cause that, try running it disconnected.
                • Gazmitchell
                  • Feb 2013
                  • 640
                  Thought it too good to be true by starting and running, now it won't fire, just turns over
                  Pulled codes and I'll have to work through em as there's 7.
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    are the light green injectors origional bosch ones?
                    there are a lot of chinacrap on the net,
                    is the bosch symbol present on the injector?
                    to much fuel can also be the white temp sensor on the back of the head
                    TWINCHARGED power,zero lag
                    AEM W/M injection
                    • Gazmitchell
                      • Feb 2013
                      • 640
                      Hi mate.
                      Hmm no they haven't any bosch symbol on em,so I indeed may have bought cheap crap. That's a positive tho, also one of the error codes came up as temp sensor . Tho this was new few years back... So for starters I'll sort new injectors, get. New temp sensor and a set of new plugs to boot .
                      • GazzaG60
                        • 4133
                        take plugs out and clean them. if the overfueled they may not fire.
