Lightweight S2?
  • AUDI9020V
    • 653
    beat me to it i was wondering that too,wot do u need to remove.it would make it alot lighter
    1990 100 2.2 10vqt 82k miles(now dead)
    1990 90 2.3 20v 166k miles
    1988 90 2.0 10v 181k miles
    oh and a polo for work.
    • NoNonsense
      Forum Sponsor
      • Apr 2004
      • 673
      #32
      Originally posted by robo
      Is this big job, can abs be removed without and sideeffects?
      cheers
      I wouldn't recommend doing this unless you've got the engine out. I redid the brakes with new lines in the front and a new line halfway to the back. It only saved about 10kg with the control unit and the wiring.
      So, in conclusion, it would be a huge job with an engine in place, otherwise, it only took a couple hours to bend some new lines. No sideeffects at all...just plain and simple hydraulic braking.
      Joe "NoNonsense"
      axis motorsport
      joe@axismotorsport.com
      "At the end of the game, the king and the pawn go back in the same box."
      • Jeffer
        • 2057
        Originally posted by NoNonsense
        - removed ABS and all associated wiring (heavy!)
        What comes with this removal? Did you use another master cilinder etc etc?
        RS2 Black - stock 315 HP
        RS2 RS blau - stock 315 HP
        Sport Quattro - 1005 HP
        High Octane website
        • NoNonsense
          Forum Sponsor
          • Apr 2004
          • 673
          #34
          Jeffer,
          I ran a line off the current (original OEM) master cylinder, to the passenger side front(LHD). Then the driver's side and the rear lines went to the bias controller. One side passes the hydraulic fluid through for reference (so that went to the driver's front wheel). The other side of the proportioning valve actually reduced the pressure for the rear line.
          On my next project car, I am removing the OEM proportioning valve completely and put a cockpit mounted Tilton adjustable proportioning valve in the center console.
          Joe "NoNonsense"
          axis motorsport
          • Martynf
            • 1885
            Hey Joe,
            Suspension, well I was due to move home, so all the parts removed from the S got bolted back into her so I dont lose / break anything in the move! she is back to her fat old self! when my move is done, then the only suspension that I can really consider is the ultra expensive KW stuff. I dont Wwant to pay that much out, but H+R are not good enough, they can only give me height, no bound or rebound. they design those kits for full wieght cars so their kits are going to be off the mark for my weird bus and the oly kit I know of in existance that give my wagon height, bound and rebound is KW, so I'm in a corner on this one....
            Hope things are good for you?
            Martyn
            [QUOTE=NoNonsense][QUOTE=Martynf]
            With 130 kilos out of the car, it came up by about 1-1.5 inches on the suspension, handled much more nimble, almost nervously I have to say!! but with all the suspension now totaly wrong and the car up by that amount, its no surprise there! if you do this, you MUST have height adjustable suspension.
            What suspension are you running now-a-days, Martyn?
            Martyn
            www.vagparts.com
            • NoNonsense
              Forum Sponsor
              • Apr 2004
              • 673
              #36
              Originally posted by Martynf
              Hey Joe,
              Martyn
              Thanks for the update, Martyn. Things are good here...I'll shoot you an e-mail to catch up.
              I'd be interested in getting some KW coilovers for my B4. There aren't any dealers in the US that import those kits...so nobody has them on their cars. With that said, I don't know much about the reliability of these kits. What makes the KWs better than the H&Rs? I'd be up for anything at this point because I'm only using Bilsteins in stock strut housings with height adjustable sleeves welded to the housing. The bilsteins aren't properly valved for my tastes.
              Joe "NoNonsense"
              axis motorsport
              • Billman
                • 4129
                #37
                Folks, I just bought an RS2 towbar so i can add 20 kilos to my car!
                Go Holset or Go RS4
