Vibrations on high speed curves ?
  • MidnightBlueS2
    • Jul 2005
    • 1653
    • Home: United States Current: Belgium
    Evenin' everyone,
    Coming home from work this evening, I was a bit over the speed limit ( 160km/h ) and I noticed vibrations coming thru the floor associated with some wheel shimmy BUT only when driving on the curves. On the straights, the car feels perfectly balanced and taut... It can't be the highway as it's perfectly flat where all this happened.
    Any ideas ?
    Thanx guyz !
    David
    Midnight Blue S2 - SOLD - 1993 S2 Avant
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Wheel bearing?
    SS
    • MidnightBlueS2
      • Jul 2005
      • 1653
      Originally posted by 4WheelDrifter
      Wheel bearing?
      I doubt it's a bearing as there is no bearing sound when it happens and when travelling at 120 km/h, no vibration, no steering wheel shimmy...
      But thanx anyway !
      • volcano rs
        • Jun 2005
        • 2265
        i have this same problem on my a6 2.5 tdi only at about 90 miles an hour and when i turn the steering slightly to the left .
        • MidnightBlueS2
          • Jul 2005
          • 1653
          Could it be the top mounts ? I don't even know what the symptoms are when the top mounts are failing...
          • volcano rs
            • Jun 2005
            • 2265
            i really dont know . i know the steering normally feels slack when the top mounts are worn but why only at 90 mph and not 100mph ?
            • dan_b
              • Sep 2003
              • 3670
              Is it only on, say, a left hand bend? Just wonder if you might have a faulty or worn tyre on one side that is vibrating under cornering load?
              • pjeast73
                • 144
                Had a similar problem a while ago - only at above 80ish speed on a motorway bend - on mine it was worn wishbone bushes causing the problem
                • YELL MAN
                  • Dec 2005
                  • 541
                  • Country: Shetland Islands
                  I had violent vibrations when going above 70mph. I replaced the front wishbone bushes last night and that cured it.
                  1994 Indigo Blue S2 coupe
                  1994 80 Avant 1.9 TDI
                  2005 Yamaha Fazer 1000
                  1953 AJS Model 18S
                  • MidnightBlueS2
                    • Jul 2005
                    • 1653
                    Thanx for all your inputs, guys ! Well appreciated !
                    • Stick Insect
                      • Dec 2003
                      • 2338
                      How about a buckled wheel on that side. I have one on my Mondeo and it shows up more when cornering and putting weight on that side.
                      vibration appears at 65mph as well
                      David
                      • MidnightBlueS2
                        • Jul 2005
                        • 1653
                        Buckling ? Do you mean as if the bolts were loose ?
                        • volcano rs
                          • Jun 2005
                          • 2265
                          yes it only happens on motorway and at 90mph on left slight turn
                          • stevieyid
                            • Apr 2005
                            • 2251
                            Mine does this. It seems to happen on left hand bends and at high speeds. Also happens when lifting of the throttle at high revs but only in third upwards. What could this be?
                            3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
                            • AUDI9020V
                              • 653
                              i get the same in my 90,lookin at all the replys and my cars i think top mounts,springs shocks and bushes should sort it out oh and the tracking.
                              1990 100 2.2 10vqt 82k miles(now dead)
                              1990 90 2.3 20v 166k miles
                              1988 90 2.0 10v 181k miles
                              oh and a polo for work.
