Sound proofing!
  • stevieyid
    • Apr 2005
    • 2251
    Sound proofing!
    Looking into sound proofing my boot and maybe a little more under the carpet just reduce the drone i get at 2-3k rpm now i have my new exhaust. Any reccomendations of any sound proofing products? Cheers
  • HPmuirt
    S2Forum April Fool
    • Apr 2005
    • 3014
    I understand that fitting a standard exhaust system would make a serious reduction in the noise you are experiencing
    Cheers and
    Si
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
    • Jon441cc
      • Dec 2005
      • 2061
      Steve, I'm going with some ''dynamat'' under the seats & spare wheel well
      • Mikes2
        • 1704
        Have you thought about taking it back and asking them to fix it.
        Mike
        http://www.s2-audi.co.uk
        • Ross
          • Aug 2005
          • 3399
          Steve,
          I've sorted mine - turn the radio up another 2 notches
          Personally I can live with it, but if I'd be a little embarrased to take passengers anywhere! They'd have a headache pretty quick I reckon...
          • Fat Audi 80
            • 10547
            That's what I would do, btu I think both Ross and Steve specified "sporty no compromise" when they had the systems built so haven't got a leg to stand on!
            I will let you know how LOUD Ross's system is after I have seen him on sunday!
            The Perfectionist
            • S2 Ant
              • 3682
              There is already a lot of sound proofing in the car as it is!!!
              Try taking off one of or both the front door cards and go for a spin, the amount of noise is unbelievable!
              When i done it i thought the door was open or something!!
              Ant
              2011 Kawasaki Z1000
              • stevieyid
                • Apr 2005
                • 2251
                Let me no how it goes jon. I was thinking of doing the boot area and see if that helps
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  How would you do that?
                  The rear quarter panel already has thick sound proofing on the back of the carpet.
                  You could put the dynamat style stick-on sound proofing on the inside of the outer wings, but you have very little access to do it. As for the final and largest panel....the boot floor, this would probably respond well, but you would have to strip most of the rear end, including the tank to access it.
                  That is a lot of work for unknown results. However, if you do decide to go for it, could I suggest that you take before and after measurements so that we get a definitive answer on this one
                  Cheers n
                  Si
                  • stevieyid
                    • Apr 2005
                    • 2251
                    Didnt realise it would involve so much work. I will wait and see what happens with Jon before making my decision. Cheers
                    • Jon441cc
                      • Dec 2005
                      • 2061
                      Steve, my bro has come up with an idea , i used to have a GT4 with a Nur Spec R(i know) it had a removable baffle which reduced the noise bigtime my bro had a
                      idea about having two baffles made for the 2.5'' tips
                      I'm going to still put a little dynamate in the wheel well + rear seats
                      • dan_b
                        • Sep 2003
                        • 3670
                        I'm with Mike on this one, take it back, get them to change the exhaust sound
                          Simply ask for another box to be added to the system so it's more like the Greg S setup
                            I only have 2 boxes on my setup now
                            The first box after the downpipe has been removed. Its a bit boomy at around 2700-3000rpm but thats the point it will resonate most and is usually the case on most cars.
                            • Ross
                              • Aug 2005
                              • 3399
                              Backbox to Longlife:
                              "Thou shalt have no other box before me"
                              And they're a faithful bunch... Steve, didn't Longlife skip the centre box in your car as well? I'm sure putting one in would really help... could get one put in if/when you get the downpipe done, it crossed my mind, but wouldn't that add a fair bit of restriction? Guess I'll keep waking the neighbours up on an early morning start... if they're that concerned, they'll fit double glazing.
                              Ross
