Samco do have AAN hose kits available thru the normal retail channels, but the S2/RS2items (3B, ABY & ADU engines) come thru me. Send me a PM and I can get you more details.
Paul
Thanks Paul. I have an AAN but it has a 3B intake. I think I can get all 3B plumbing on it.
I saw the price at around 210 pounds, is that right? Do you happen to have a picture of the hose set so I can determine if they will work for me?
It will be a little while before I need them as I have to get the car imported from Canada to the U.S. and also source the stock 3B hard pipes.
Thanks,
Dave
Dave K.
USA
1991 e//S2 (home built S2 - the only way to get one in USA!)
2001 S4
What I think that Dave is trying to say is that the coupe has an ersatz ABY engine, based on an AAN with an intake manifold off a 3b ( likely a 200 3B)
Most of us "converters" follow the route of either a 3B from a US -spec 1991 200 with the 3b ( same intake as the 3b S2) or use the Ur S4/S6 AAN with the 3B intake and the 3b head coolant manifold.
-Peter
Peter S
1990 ErsatzS2 - track toy
1991 Coupe Quattro
1991 Coupe Quattro
1995 S6 Sedan
1995 S6 Wagon
After some further investigation, it looks like I have a stock ABY manifold on my AAN (which is essentially an ABY). Looks like I have an ABY pretty much.
Certainly ABY-esque there. Assume you know that pressure pipe into the throttle body is not ABY standard equipment. WIth the factory ABY or ADU pressure pipe - get a late plastic one if you can - you will be just fine with a set of ABY/ADU Samco hoses.
