Steam Cleaning Engine Bay?!
  • s2dude
    • Nov 2005
    • 1631
    Is anyone aware if the S2 steam cleans ok??
    I know its not normally advised but I've done it on loads of other cars and it's been fine.....
    I'm hoping someone here has done it on there S2 or if anyone can tell me if there is any areas to pay particular attention to?
    TIA
  • rotoryboy
    • May 2004
    • 3281
    TIA
    No no no no no no. Use a degreaser and/or carb cleaner or similar. The problem is the pressure as it forces water to the places it should never go. You will have problems afterwards. Take your time and do it the hard way
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • Ski
      • 2591
      Hee hee... i stemed cleaned mine and it was fine.. then I did it again and it caused £400 damage...
      ABY Coupe
      • Fat Audi 80
        • 10547
        Do a search on "engine bay" and you should be able to find the thread where I described cleaning mine.
        Very quickly:
        1.) Buy Autoglym Machine cleaner & Autoglym Vinyl & Rubber Protectant
        2.) Spray AG MC all over engine
        3.) Agitate as required with brushes etc
        4.) Rinse carefully with domestic hose avoiding staying over electrical components for too long (engine off)
        5.) Start engine and close bonnet to allow engine to dry a bit
        6.) Spray AG V&R protectant liberally all over engine
        7.) Run engine and close bonnet again to allow to dry (or go for a drive )
        8.) Open bonnet and admire handy work!
        I also used another good product for this which can be found on the other thread about this....
        Cheers,
        Steve
        The Perfectionist
          Dont even consider it unless you like chasing electrical gremlins for ages after.
          • Fat Audi 80
            • 10547
            The engines are designed to be splashproof they just don't like pressure washer water being forced into the sensitive areas. Go steady with a stream of water from a mains supply and you will be fine. Obviously don't stand there for 5 minutes washing your coilpacks or forcing water into the electrics though!
            I have done this two or three times and everyone knows how pampered my car is....
            The Perfectionist
            • Keeper of The Kitten
              • Dec 2003
              • 2317
              Steam cleaning is the bane of MAFs / Air Meters, whatever make of car you drive!
              __MDC__
              Martin Cutting
              • ericd
                • Nov 2003
                • 1240
                TIA
                As others intimate it's usually a bad idea because it's typically done with a pressure washer and a not a real steam jet...
                • s2dude
                  • Nov 2005
                  • 1631
                  mmm....Ok. Thanks guys
                  looks like a big no no then
                  I will search the forum for other posts on engine cleaning and follow the advice Fat Audi80 kindly left.....
                  Looks like hard work is the only solution to this one !!
                  • Fat Audi 80
                    • 10547
                    It really isn't that hard. 1/2 hour to an hour will see you with a sparkling engine bay....
                    The Perfectionist
                    • s2dude
                      • Nov 2005
                      • 1631
                      You havent seen the state of my engine bay mate
                      • Fat Audi 80
                        • 10547
                        Let's see some before and afters when you do it then?
                        The Perfectionist
                        • s2dude
                          • Nov 2005
                          • 1631
                          ok. good plan!
                          I will take a round of pics and post em up after the weekend
                          • pastures16
                            • 2058
                            no dont do it
                            i did the same thing when i got my s2 looked loads better but its no good when it wont run
                            b4
                            after
                            94 s2 avant
                            aoc member 1116
                            • Fat Audi 80
                              • 10547
                              Originally posted by pastures16
                              That really WAS nasty!
                              I think if you are careful you will be fine. All the connectors are at least IP42 allowing wash down.
                              Just don't go mad!
                              The Perfectionist
