can anyone tell me how much longer an rs2 is than an s2 coupe cheers me dears
rs2 length!!
Originally posted by vonbeckcan anyone tell me how much longer an rs2 is than an s2 coupe cheers me dears
Are you trying to decide whether one would fit in your garage??
Ragusa Coupe gone!
vw T5 Kombi. In the process of being "ruined"Comment
S2 coupe is 4401mm, all the specs (width height etc) are on http://www.s2central.net/main_frame.html
PaulComment
I spent a grand relaying my drive to get my S2 in the garage, i know what mental maths looks like broOriginally posted by vonbeckhow did you guess
or whether to do "the mods" to my aby coupe
Ragusa Coupe gone!
Originally posted by vonbeckcheers cant decide wether to bite the bullet and go for an rs2 or give mine the 350- 400 bhp mod
I had the same dilemna but decided on keeping the Coupe (Mrs hates the Avant bodystyle with a passion!
If i was you i'd uprate your Coupe as it's a rare colour, but then there is the prestige of saying you own an RS2
what do you think the cost of the mods for this sort of thing will cost just engine etc iv`e thought about £3000 would i be right in saying i need
new turbo [but which one]
exhaust manifold
green injectors
re map
fuel pump
is there any thing else not realy going for 400 bhp about 350-380 would be niceABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
Decide on your BHP level if you saying 350-380 then it's RS2 turbo spec.
Shouldn't require a bottom end rebuild at that bhp but get it checked.
If you wanted just over 400 the GT2871 and 3071 will get you to 450bhp, will need new rods i reckon to take the torques
Budget for
Turbo + Manifold
Head Gasket change
Injectors (MRC sell cheaper ones than the RS2)
Exhaust (You've got) but probably recommend a new downpipe
Remap + map sensor for ecu
044 Fuel Pump
Optional having the head pressure tested for leaks and cracks.
You can run 320 bhp on ABY injectors and fuel pump but better to be safe.Comment
no i dont want to do the bottom end, but is there not a better turbo than the rs2 one i`ve done some reading through old threads and now im more confused than before
