clutch M cyl bar just snapped
  • T2Andy
    • 1903
    Just coming home from a night out ,clutch in to change gear and snap ,the plunger bar broke in two no clutch had to do 7miles in second .driving into my garage was quite tricky
    Does any one have a spare or how much and where from could do with one as soon as poss . You did worn me Bry cheers and tears, ANDY
  • T2Andy
    • 1903
    Thanks to S2AVANT ie Ben my car is back on the road with a nice smooth operating clutch ,ben supplied the master cylinder and it arrived in one day nice one .
    Bit of a pig to fit mainly because theres not a lot of room under dash and engine bay
    but managed to bleed it with easy bleed which you can find at all good motoring outlets!
    if any one wants the method in fitting this pm me to avoid temper tantrums cheers.
      T2Andy can you create a guide and top tips post please on the fitting of the M Cyl?
      • T2Andy
        • 1903
        will do it might not be the best but it worked for me
        • Si Blythe
          • Jul 2005
          • 346
          Master cylinder
          Hi Andy, I believe my master has gone, already changed the slave and still no pedal and no fluid coming out of it when bled. Do you have the link to the guide you put together when you did yours?
          kind regards Simon
          You might leave the S2 fold every so often - but you'll always come back!
          • HPmuirt
            S2Forum April Fool
            • Apr 2005
            • 3014
            Hey Andy,
            Do you remember seeing my MC and bar at Combe last year? Did yours show similar wear patterns? I ask as I wonder if this is a weakness that should be investigated for a permanent solution, such as a stronger (Titanium or hardened steel?) rod
            Cheers n
            Si
            Subtle mods here and there
            2011 A5 3.0 TDi - Lava Grey
            • T2Andy
              • 1903
              I dont think the bar needs to be stronger as mine lasted 12yrs and 75k miles i think if it was lubricated occationaly this might help ,i do remember you from castle combe and your
              dirty green s2 as to fitting its very awkward as you have to be under the dash upside down ,its also tight under the bonnet.pm me for my no if any one wants any advice ,
              i sound like a pro.
              • BRY
                • 3755
                Can I have some advice, please Andy?
                • T2Andy
                  • 1903
                  ofcourse wash your bloody car.
                  • Graham
                    • 1622
                    I found mine a bit fiddly aswell, mine had almost snapped, bleeding it wasnt as bad as i thought either.
