Launch RPM?
  • YELL MAN
    • Dec 2005
    • 537
    • Country: Shetland Islands
    Launch RPM?
    Hi i was wondering what RPM's was best for launching a standerd S2 with a homefry up the quarter mile. I usually launch at 3500 RPM but im scared to go any higher for fear of breaking something. Thanks for any advice.
    1994 Indigo Blue S2 coupe
    1994 80 Avant 1.9 TDI
    2005 Yamaha Fazer 1000
    1953 AJS Model 18S
  • porkkis
    • 1994
    • jogi730
      • 2335
      I have been led to believe it's 5250 rpm, where the torque and power lines cross on any engine
      Chris
      Audi 90 quattro (Typ 85)
      20v turbo conversion
      • YELL MAN
        • Dec 2005
        • 537
        Ok thanks i will try 5000rpm first and see what happens, i was just worried that it would be to much for the clutch to handle.
        1953 AJS Model 18S
        • porkkis
          • 1994
          It'll hold if it's not on it's way out already and you don't let it slip.
          • MidnightBlueS2
            • Jul 2005
            • 1653
            • Home: United States Current: Belgium
            I can vouch for that !
            Midnight Blue S2 - SOLD - 1993 S2 Avant
            • sorens2
              • 241
              • Country: Denmark
              I launch @ 5700
              Tried 5200 but that was not enough.
              450 BHP
              Søren S2
              Audi RS4 LO550
              BTG 8:08
              www.fredslunds.dk
              • s2munckton
                • Jan 2006
                • 66
                • Country: Australia
                Maybe a stupid question, but at 5000ish are you dumpling the clutch or do you let it slip a little?
                Good Question Yell Man
                Rich aka s2munckton
                94 Audi S2 coupe.
                • s2munckton
                  • Jan 2006
                  • 66
                  ahh, not dumpling the clutch, i meant to say "dumping"
                  whoops, you can guess what i want for dinner!
                  Rich aka s2munckton
                  94 Audi S2 coupe.
                  • YELL MAN
                    • Dec 2005
                    • 537
                    Ok i had a few practice shots at 5000 rpm, what a differance it's made the car was even leaving skid marks on the road on take off . By the way that was with dumping the clutch rather than letting it slip. cheers for the advice.
                    1953 AJS Model 18S
                    • aronmatic2
                      • 2129
                      • Country: Hungary
                      nobody can tell what is the best launch rpm.
                      depends of lot of things.
                      what is the material of road.
                      what kind of tires you use.
                      what is the size of your tires.
                      what kind of weather, what temperature.
                      lots more.
                      i have launch control. i use between 5200 and 5800rpm.
                      dont try under 4000rpm. very dangeorus, you can break something easyly.
                      Real carbon parts for S2 and RS2. Check Carbondesign on facebook
                      • YELL MAN
                        • Dec 2005
                        • 537
                        So using 3500 rpm could explain this
                        1953 AJS Model 18S
                        • aronmatic2
                          • 2129
                          • Country: Hungary
                          maybe.
                          try like this:
                          push the clutch pedal in.
                          engage the clutch slow.
                          when you feel the clutch is start to hold, push back
                          one centimeter.
                          launch to 5000rpm and engage the clutch fast.
                          never going to happen again.
                          need some practice
                          • Chris5044
                            • Feb 2005
                            • 1663
                            when u guys say dump ... is it safe to say that u are simply stepping off the clutch pedal?
                            i did an accidental launch at 4000rpm wicked but tried higher and clutch burn n going nowhere
                            • QuattroFever
                              • May 2006
                              • 1360
                              lots more.
                              How can less rpm break things easier?
                              To little power to spin the wheels so more strain on the drivetrain?
                              If thats the case then I would have thought that it's purely down to what size/grade tyres you have and not rpm related, no?
                              Hope I've not sealed my own coffin asking this ques.
                              Come on someone sci-slaughter me.
                              Volcano ABY coupe
                              Ant
