I have put this in the general forum as I was just hoping for a general discussion and opinion session...
Standard 3B airbox gets removed and replaced with a decent quality Apexi dry filter cone, decent heatshielding and reasonable cold air intake sorted...
Why does the car suddenly keep cutting out with overboost protection?
(This is absolutely not heat soak related....)
Apexi cone removed and replaced with complete standard 3B setup again, works perfectly with no overboost protection cutting in....
Any ideas?
How do other people run cones, or other intake upgrades?
Chris
Any ideas?
Chris
. It's from S4 original airbox. However I still think, that there can be leak in the intake somewhere...
sorry, but with reference to the cross plate, if the MAF still has the mesh on the Filter side , how is a cross plate or any other pipe work gonna influence the flow drastically when it has to pass thru the mesh last before it enters the Maf ?, or is the assumption that the mesh has no relevant influence on the flow entering the Maf ? Or maybe I'm confusing myself on this...
