Cabon Fibre thermal inlet deflector..
You don't know how much they are!
I will stick my neck and say I don't really like the IM cover but DO like the airbox one.
Cheers,
SteveThe Perfectionist
Form over function!
Take weight off not put it on even if it is carbon and doesnt weight alot
Pete'If you ain't broke it you ain't trying hard enough'
Oh sh*t i broke it
94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
My RS2 box edges are bust, Parcelforce for youOriginally posted by Fat Audi 80You don't know how much they are!
Cheers,
Steve
they'd be ideal to cover the damage.
Thanks for the advice steve
The covers are just real carbon sheet with 3M backing. The inlet is 1mm alloy sheet
cut and shaped then covererd .I was bored ,had the stuff so thought i try and smarten
the engine bay total cost 20 quid they only weigh an oz or so pete.
The LMs should save a.few kg
The inlet looks quite rough standard imo.sigpicComment
youd better polish up that inlet charge pipe to loose those few grams then hadnt you
Oh sh*t i broke it
I would like to have the IM off and beadblast then clear lacquer or powdercoat, same with the cam cover and coil pack cover, but I don't really want to take it apart. I may do some work like this over the winter....Originally posted by T2AndyThanks for the advice steve
Cheers,
Originally posted by Fat Audi 80I would like to have the IM off and beadblast then clear lacquer or powdercoat, same with the cam cover and coil pack cover, but I don't really want to take it apart. I may do some work like this over the winter....
Cheers,
Steve
You mean like how mine has been done?
Claws out
Seriously though... other than Carbon being generally gorgeous... what is the alleged benefit of this ?
PaulPaul Nugent
It deflects thermals rising from the manifold ,breaks them up and disperses them evenlySeriously though... other than Carbon being generally gorgeous... what is the alleged benefit of this ?
into the engine bay .It does FA realy just a bit of bling .Just need some blue pipes to finish the job.
sigpicComment
