BIG BLUE 1200 tonne crane
  • Graham
    • 1622
    Had to do a presentation on cranes at work and used this video to show what cutting corners can do.
    The crane was only supposed to work in 17Kph winds but they were getting gusts of 25Kph even though the average was 15. The result the king pin which is the 2 bangs you hear has sheared--It is 2 foot diameter high tensile steel and it shears like a carrot In the distance you can see another crane with a man basket in, these were the people coordinating the lift, and they died as well as their crane driver-they were 500M down the road.
    Graham
  • rotoryboy
    • May 2004
    • 3281
    Oooh ya phooker
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • s2dude
      • Nov 2005
      • 1631
      Graham
      Sheesh...It must have taken some massive forces to shear that kingpin..
      You wouldn't have thought 8kph of wind gusts could be so crucial
      • DJones
        • Jun 2005
        • 2020
        Does not sound like there was much safety factor in that design!
        • YELL MAN
          • Dec 2005
          • 538
          • Country: Shetland Islands
          Holy Crap
          1994 Indigo Blue S2 coupe
          1994 80 Avant 1.9 TDI
          2005 Yamaha Fazer 1000
          1953 AJS Model 18S
          • philS2
            • 356
            small amount of H.S.E. on site after that .what weight was in that lift?
            • Graham
              • 1622
              The roof apparently only weighed about 150 tonne, but the reach is what made them need big blue, the gust only pulled the roof about 4 feet but it was enough to side load the pin and shear it.
              • tom
                • Dec 2004
                • 282
                these crains are real monsters, i have been working in Egyptian cement factory when we had one 1000 ton crane. it was very impressive.
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  I just got home from a week in Dubai and they may not have the biggest, but it is certainly true that they would seem to have most of the worlds cranes....makes a very odd skyline....
                  Cheers n
                  Si
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
                  • blown_vr6
                    • Apr 2005
                    • 406
                    Are you sure - ive been reading up on this since you posted it and from what ive read it was 450 tonnes??
                    'If you ain't broke it you ain't trying hard enough'
                    Oh sh*t i broke it
                    94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
