right, yesterday I saw a picture of the rs2 hardline and goodridge flexi hosing on an s2, but now I can't find it at all! Please can someone locate it for me as Im fitting the brakes now and just can't see where the rs2 line fits in!
Phil
...ever since I floored you I knew that I loved you!
The hardline fits onto the caliper, if you have the part numbers on them still, then the odd number is the passenger side and the even number the drivers side (UK car only). It is possible to place it through the bracket that bolts to the strut and then a slight tweak to connect it to the flexi.
Correct Martin! Spoke to corey, its OK there was a mix-up unfortunately, but tbh it might have worked out better. Really wasn't too keen in fitting that massive RS2 hardline to the car, just doesn't look right to me! Will get the other hose soon to replace the old S2 one. (might do the rears while im at it and get new disks and pads back there to try and claw back some of the brake bias!!!)
