HELP -996 brake line pic needed
  • S2 PTH
    • Dec 2005
    • 421
    • Home: Wales Current: United Kingdom
    Hi,
    right, yesterday I saw a picture of the rs2 hardline and goodridge flexi hosing on an s2, but now I can't find it at all! Please can someone locate it for me as Im fitting the brakes now and just can't see where the rs2 line fits in!
    Phil
    ...ever since I floored you I knew that I loved you!
  • Corey
    Banned
    • Sep 2003
    • 2793
    The hardline fits onto the caliper, if you have the part numbers on them still, then the odd number is the passenger side and the even number the drivers side (UK car only). It is possible to place it through the bracket that bolts to the strut and then a slight tweak to connect it to the flexi.
    Corey
    01636 822288
    • S2 PTH
      • Dec 2005
      • 421
      ah ha.. i was connecting the flexi end to the calliper!
      one thing i cant work out at the moment is why the flexi hose has an angled bit at one end?
      • Corey
        Banned
        • Sep 2003
        • 2793
        That doesn't sound right
        Corey
        01636 822288
        • S2 PTH
          • Dec 2005
          • 421
          at one end of the flexi hose, there is a 90 degree bend. is that right?
          • rotoryboy
            • May 2004
            • 3281
            Any good?
            Mark
            Race Clio RS197
            S2 Coupe ABY (Green) - RIP
            S2 Coupe ABY (Blue) - Sold
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              I originally made hardlines to replicate the RS2 items, but after a while decided they were a crap idea, so I went back to using two flexi lines.
              @Rotoryboy - It looks like your dampers haven't been changed for a while.
              SS
              • rotoryboy
                • May 2004
                • 3281
                That pic was ages old. Had brand new ones fitted last week
                Mark
                Race Clio RS197
                • martinjs
                  • 3205
                  No, that sounds like an RS2 rear hose.
                  • S2 PTH
                    • Dec 2005
                    • 421
                    Correct Martin! Spoke to corey, its OK there was a mix-up unfortunately, but tbh it might have worked out better. Really wasn't too keen in fitting that massive RS2 hardline to the car, just doesn't look right to me! Will get the other hose soon to replace the old S2 one. (might do the rears while im at it and get new disks and pads back there to try and claw back some of the brake bias!!!)
