3B advice needed. Help!!!
  • AudiCoupeParts
    • Feb 2007
    • 347
    Hi all.
    I am doing a 3B engine swap on my US spec Coupe Quattro.
    I can't seem to get my fuel pump to start when I turn the key. The car cranks over fine.
    I noticed when I do turn the key I hear a faint click in my ECU, the aux. water pump for the turbo comes on for a moment and stops.
    I hear very faint sounds from the fuel pump attempting to run ONLY when I manuelly push down on the fuel pump relay contacts. I took the cover off of it. Nothing else happens on the car.
    I hot-wired my pump and it runs fine.
    How can I check voltage at the relay contact points in the fuse box?
    TIA
    joe
    have you checked the fuel pump relay is working?
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      relay
      Check the wire from the ecu pin nr. 3 till pin S at the B blak plug from main fuse box.
      I have done the same swap.Hope that helps.
      Eugen
