Yes, as mr Nuvo says. 5/16 (8mm) copper pipe. Most decent motor factors sell it.
Then a pipe flarer: http://www.machinemart.co.uk/shop/pr...pe-flaring-kit
Just position your pipe in the holder, use the big "T" handle part and not the insert, this will give the cone shape flare you are after!
Don't forget to the unions on first!
I usually feed the unflared pipe up from below, do your engine bay bends then flare and screw together, back under the car and finish off at the tank end.
Same for the return pipe.
