B3 to B4 conversion?
    Done a quick search but couldn't find much - wondered if the headlights, bonnet and bumper off a B4 would fit straight on to a B3 coupe? Or is it more complicated?
    Seen some parts cheap and might be laying my hands on a B3 coupe soon
  • Acidburn
    • 13459
    As long as you get b4 parts yes they will, I put a b4 front on my b3 20v quattro sport. You need the 3 panels behind the headlights/under the bonnet (slam panel) as well. Its pretty straight forward to swap them over and about an hours work depending how good you are swapping panels. Btw the b4 wings are flared out more than b3 ones as I found with mine.
    • Jas11n
      • 5067
      All coupe wings were the same (larger flare) from 1988 to 1996
      Was only the B3 80 and the 90 that had the smaller flare.
      Jas..
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • Jas11n
        • 5067
        Oh, and there are a couple of variations of the "T" shaped slam panel. One variation extends right down the front quite a way (16v Coupe), whereas the version from say an S2 is quite short as it bolts to the cross member just under the aux rad.
        All depends which model it came from.
          cool. thanks guys
          • coupegt
            • Jan 2005
            • 218
            • Country: Denmark
            did a conversion on a friends B3 90 20v a few months back.
            All B4 parts were a straight fit, but my old S2 headlights had a different electrical plug, so they did not fit. We fixed up a converter with some wires, but the plug itself can be swapped for easier fitment I think
