Autocheck Oil warning
    I'm getting an oil warning from the autocheck just on the ignition, befiore the engine starts. The level reads fine and no warings when driving - oil pressure looks a bit low, but not much less than usual - 2 bar at idle to 5 during normal driving.. is this a switch or sender failure?
  • Acidburn
    • 13459
    Check the relays under the steering column console are seated properly i've heard people having this problem before.
    • volcano rs
      • Jun 2005
      • 2265
      2 bar at idle is fine you don't need to check any relay
        how come the warning on ignition? - 2 bar is only the minimum safe pressure is it not?
        It normally urns at 2.5 ish, and off the scale on normal driving
        • volcano rs
          • Jun 2005
          • 2265
          what oil are you using ?
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              mine is at 2.2 or 2.3 bar at idle and im using 10W60.Before the rebuild it was staying at 1.8bar and when hot even lower.I guess a good oil pump and good piston rings will give you a better oil pressure!
              • Flat on my back
                • Jan 2007
                • 2449
                Bentley needed?
                2 sensors, high and low on 20v NA, below .8 bar ign. off and above 1.8 ign. on.
                Could be sensor or wiring, do you know Pixy... on here?
                PM me for info if you want?
                Carlos.
                • Azman
                  • Sep 2005
                  • 3205
                  Prob the sender....
                  Dark Grey Avant
                  RS2 FARB
                  Alloy Subframe Bushes
                    where abouts on the block / sump is the sender?
                    • AUDI COUPE 20V
                      • Nov 2005
                      • 251
                      sender is on the right hand side under inlet manifold on the block quite aqward to get to
                      2 switches there big cylinder one and a small one
                        'behind' the rad? IIRC I noticed 2 switches / senders on the side of the block there when I was changing it last week
