I'm getting an oil warning from the autocheck just on the ignition, befiore the engine starts. The level reads fine and no warings when driving - oil pressure looks a bit low, but not much less than usual - 2 bar at idle to 5 during normal driving.. is this a switch or sender failure?
Autocheck Oil warning
Originally posted by Error404 View PostI'm getting an oil warning from the autocheck just on the ignition, befiore the engine starts. The level reads fine and no warings when driving - oil pressure looks a bit low, but not much less than usual - 2 bar at idle to 5 during normal driving.. is this a switch or sender failure?
Bentley needed?
2 sensors, high and low on 20v NA, below .8 bar ign. off and above 1.8 ign. on.
Could be sensor or wiring, do you know Pixy... on here?
PM me for info if you want?Carlos.
