will a B6 3.0tdi work in a B5 A4?
  • Gazjen
    • Oct 2008
    • 223
    You will have probs with the immobilisers unless they can be deactivated or recoded to each other, What about using the original dash from the B7 could it be modded to fit?
    My 2001 S6 engine sends a lot of info to the dash via the can bus wiring but it also relies on simple wiring for warning lights etc so you may lose some functions if you intend to keep the 99 dash (If you can get round the immob issues)
    URQ 20vt converted
    80 quattro saloon with on going a V8 transplant
    • BRY
      • 3755
      Can't you wire the engine as the 2.5 and have it mapped to suit the 3.0 on the original loom?
      • WabTheKing
        • May 2004
        • 2567
        completley different engines bry,
        is the imobilzer in the engine ecu? or does it have a standalone imobilzer that gives the engine ecu a signal voltage to allow it to start?
        • Gazjen
          • Oct 2008
          • 223
          Its part of all three the key the clocks (Dis) and the ecu all have talk to each other to run
          Without it the engine run for around 2 seconds and then stop, Its not a simple as just applying a voltage any more unfortunately
          URQ 20vt converted
          • bikerjim
            • Feb 2008
            • 1028
            Originally posted by WabTheKing
            ok i have the wiring diagrams now :-D
            now from what i can make out reading up on can bus,
            can bus is a shared information system like a local area network,
            so engine speed information etc may be shared with traction control etc, and signals from all ecus are linked to the dash to bring up warning signals via a processor rather than a wire to a bulb.
            only can bus item i can see on the b5 is the dash link?
            Ok cool, glad you got that sorted. The rest is a little beyond me I think, dont know much about can-bus, actually I dont know anything about it lol
            • WabTheKing
              • May 2004
              • 2567
              isnt there a feature on vagcom to re sync keys and imobilzers?
              • Gazjen
                • Oct 2008
                • 223
                Not sure I thought when Audi did it. It transmitted the codes to the central head office server thing and they rejigged it from there (hope I haven't lost you in the tech speak )
                ie the dealer can't do it without an uplink. I'm not that hot on vag com yet still learning.
                URQ 20vt converted
                • WabTheKing
                  • May 2004
                  • 2567
                  could something like this be the answer?
                  • allyb
                    • Mar 2012
                    • 6
                    3.0tdi into B5 ?!
                    did this transplant go ahead ?
                    • ManiacuV6
                      • Dec 2009
                      • 458
                      • Country: Romania
                      #25
                      A really nice project ! As far as i know the 3.0TDI from B7 is with IMMO 4 generation. For this i have a solution to cancel the immobiliser. But another main issue is the CAN network . ABS+ ESP for example use CAN to cut your throttle for ESP. On your B5 do you have ESP or only ABS ?
                      Audi S4 2.2T 5 spd 1992 for parts
                      AUDI A4 1.9TDI daily use
                      Audi 80 Quattro 2.0 16V (ACE) aka Competition
                      • Sleeper_Avant
                        • 2372
                        will the b5 dash/imobilzer work with a b6 ecu?
                        will it wire in............. good luck fella!
                        totaly different immob setups between immob 3 and 4, canbus systems not compatable and unless you splice the B7 harness as a stand alone system, i.e seperate to the rest of the car harness, then yes it will but you will always have running problems and fault codes as the 3.0 is linked in to ESP, brake and or clutch pedal switches, steering angle sensors and gearbox sensors.............
                        i looked into the 3.0 and V8tdi`s and ruled it unfeasable.
                        i can tell you that you can totaly remove the engine and ECU and harness complete from the ECU point next to the servo complete in one lump and everything else on the car will function perfectly, only difference ive done with mine is wired 4 wires on AAN harness to power it, spliced into the harness for re counter, battery light and fuel pump relay.
                        faults i have:
                        ABS, Engine managment, Immobliser lights and buzzers making constant flashing/noise as it knows its been raped of the origional clocks and ECU!
                        but if your retrofitting a FULL stand alone harness/engine like i have then your laughing
                        • europeanme
                          • Oct 2005
                          • 3817
                          anything is possible....
                          • WabTheKing
                            • May 2004
                            • 2567
                            • WabTheKing
                              • May 2004
                              • 2567
                              engine sits bout 25mm forward from the gear box for some reason so looking to see if the old engine mounts may be used or if ive got to modify,
                              imobb in the engine ecu is sorted....... or so im told
                              the car doesnt have esp, only abs so have to just see what happens with that and the dash signals.
                              abs i can live without to be honest,
                              i have one rear rs4 door, (n/s) so still hunting around for other pannels
                              sticky one is the rear quarters
                              may be putting 20" x 9 bentley flying spur 7 spokes on it....... undecided tho really want some rotiforms
                              • Sleeper_Avant
                                • 2372
                                you should just be able to use the 2.5 mounts?
                                hope you have better luck than i did with wiring and immobliser issues
