A4 1.9 TDI Windows not working
  • A4 1.9 TDI Windows not working
    My mate's car, 2004 avant model
    Windows have stopped working and the boot won't open.
    What's the best way to proceed.
    Ccm under passenger carpet is quite possibly faulty,quite often caused by water leaking through from scuttle panel area
    Do a scan with vcds,it may show 30+ errors on the doors etc
      Ah yes, maybe the ol' blocked scuttle drain scenario
      Cheers James, we'll check that. [emoji106]
        Scuttle is dry
        Ccm is dry
          VAG-COM Version: Release 311.2-N
          Control Module Part Number: 8E0 959 433 AH
          Component and/or Version: Komfortgerát T1B 0617
          Software Coding: 07115
          Work Shop Code: WSC 63351
          Additional Info: 8E2959802B Tõrsteuer.FS BRM 0002
          Additional Info: 8E2959801B Tõrsteuer.BF BRM 0002
          Additional Info: 8E0959801A Tõrsteuer.HL BRM 0002
          Additional Info: 8E0959802A Tõrsteuer.HR BRM 0002
          6 Faults Found:
          01371 - Alarm triggered by Door Contact Switch: Driver's Side
          35-00 - -
          00532 - Supply Voltage B+
          37-00 - Faulty
          01811 - Supply Voltage for Door Controller: Drivers Side (J386)
          37-00 - Faulty
          01331 - Door Control Module: Driver Side (J386)
          80-00 - Single-Wire Operation
          01560 - Passenger Door
          61-10 - Won't De-Safe - Intermittent
          01562 - Right Rear Door
          CCM Before clearing codes
          9 Faults Found:
          01616 - Signal Wire to Interior Monitor
          79-10 - Please Check Fault Codes - Intermittent
          01370 - Alarm triggered by Interior Monitoring
          35-00 - -
          00962 - Alarm via. Tilt Sensor
          35-00 - -
          01368 - Alarm triggered by Luggage Compartment Switch
          35-00 - -
          35-00 - -
          37-00 - Faulty
          37-00 - Faulty
          Automatic full scan...
          Chassis Type: 8D - Audi A4 B5
          Scan: 01,02,03,08,15,17,25,35,45,55,56
          Address 01 -------------------------------------------------------
          Controller: 038 906 019 FP
          Component: 1,9l R4 EDC 0000SG 1467
          Coding: 00002
          Shop #: WSC 63351
          WAUZZZ8E92A212262 AUZ6Z0A0369181
          3 Faults Found:
          17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
          P1586 - 35-10 - - - Intermittent
          17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
          P1256 - 35-10 - - - Intermittent
          16955 - Brake Switch (F): Implausible Signal
          P0571 - 35-00 - -
          Readiness: N/A
          Address 03 -------------------------------------------------------
          Controller: 8E0 614 517
          Component: ABS/ESP front 1726
          Coding: 04255
          Shop #: WSC 06435
          2 Faults Found:
          00526 - Brake Light Switch-F
          27-10 - Implausible Signal - Intermittent
          01200 - ABS Valves Supply Voltage
          Address 08 -------------------------------------------------------
          Controller: 8E0 820 043 B
          Component: A4 Klimaautomat 0912
          Coding: 00000
          Shop #: WSC 63351
          1 Fault Found:
          00819 - High Pressure Sensor (G65)
          07-10 - Signal to Low - Intermittent
          Skipping Address 15-Airbags
          Address 17 -------------------------------------------------------
          Controller: 8E0 920 950 F
          Component: KOMBI+WEGFAHRS. RB4 D26
          Coding: 00400
          Shop #: WSC 00016
          1 Fault Found:
          01039 - Coolant Temperature Sensor (G2)
          30-10 - Open or Short to B+ - Intermittent
          Address 25 -------------------------------------------------------
          Controller: Bitte Adress
          Component: e 17 eingeben
          No Faults Found
          or DTCs not supported by controller
          or a communication error ocurred
          Address 45 -------------------------------------------------------
          Controller: 8E0 951 177
          Component: Innenraumueberw. 0604
          Coding: 00001
          Shop #: WSC 00000
          1 Fault Found:
          65535 - Internal Control Module Memory Error
          00-00 - -
          Address 56 -------------------------------------------------------
          Controller: 8E0 035 195
          Component: symphony II NP2 0100
          Coding: 00001
          Shop #: WSC 00045
          No fault code found.
          End -------------------------------------------------------
            Id check wiring in the bellows mate. My b6 did a similar thing and several wires were split.
              Yes, been repaired before and a bit of a mess, needs doing properly
                I just replaced the loom for a new one. Thats if they arent NLA now. I couldnt even get a rear ABS sensor for my B5 RS4 recently.
                  Door loom? Is it plug and play?
                  There's something odd about the wires at the plug in the door jam. I tugged and the plug pulled out but there were some wires going straight through the other half of the plug, I reckon someone's bypassed a couple of the pins..
                  Ran out of time and energy with it last night
                    Yes plugs into a post connections rest just threads through door to various points. Easy. Easier than a repair that lasts 6 months
                      I think the the A post connector might be messed up too
                        As long as tbe female socket in the a pillar is intact then you will replace the lot.
