UrS6 Broken pedal box + clutch master cylinder
  • John.
    replied
    Originally posted by Nuvo
    Shaun on here is breaking a UrS6, he might have a serviceable pedal bracket you could use.
    Weld it/strengthen it before you fit it !
  • Nuvo
    replied
  • John.
    replied
    I would say if you can find a "flexible welder" then it would save you time on removing the pedal box. By "flexible welder" I mean someone like yourself who will physically be able to lie on his back and get in there with a mig welding torch.
    Have a word with a friendly blacksmith, at worst take out the box and get them to weld it up. Having it repaired will likely make it stronger than before?............obviously the importance of it being welded in the right place is paramount !
  • Michael S2
    started a topic UrS6 Broken pedal box + clutch master cylinder
    Folowing on from this thread...
    So my worst fear was realised after removing the plastic trim to gain better access to remove the clutch master cylinder. One cracked pedal box
    Quick recap of how this happened....
    Went to change gear as normal and heard a crack/pop and felt strange movement in pedal. At this point the clutch pedal only returned about halfway and bite point of clutch was near the floor. So i thought i'll need to get that looked at, but car was still driving fine for the next few days. Until gear changes became difficult to the point where i had no clutch pedal as it was on the floor. Changing gears with no clutch is doable but then i had to stop at a junction...game over . Flat bed recovery job home.
    Was hoping it was just the master cylinder but on closer insection the pedal box is cracked. So the initial cracking sound will have been the pedal box going. After that the extra stress on the master cylinder means it was inevitable this would break.
    So if you feel like something has broken get it parked up asap or you will just break the master cylinder or something else. I learned this the hard way. Some will say a clutch change could have prevented this, but my pedal was not particularly hard to press. So i'd say it's just luck if your pedal box is going to break.
    Some photos attached. Is this fixable in place? At this moment i have no idea who i can get to fix this.
    This gallery has 4 photos.
