New urs6 build
Nice project! I had also some problems with the 7a flywheel and MaxxEcu. Changed the flywheel to aluminium Leanders and it worked nice. What's next in the "to do" list?
- 1 like
3> filling the flywheel pin with material , not close to the flywheel , not far ... just feel lucky !
So , we got the car started today thanks to Norbitron and Marc from Efi ! Please keep in mind three things when choosing Vems and 7A flywheel over AAN cabling system :
1> Polarity of the TDC sensor pins: pin 1 <> pin 2
2> Distance between TDC sensor and the flywheel pin should be as small as posssible( 1-2 mm ).
This gallery has 3 photos.
- 1 like
Real nightmare on starting the car for the first time... after many hours of tshooting we found by mistake that the pin on the flywheel was made of stainless steel...
We had to grind the surface with a biax and fill with material and grind again for a clean surface.
Originally posted by marius555 View PostThe power should be somewhere arround 500hp, as i am going with stock AAN cams. Also i have some issues with the injectors that i think are too big combined with RON100 and possibly not having a good idle.
Will post more pictures these days.
We moved the pin of the brake pedal with 2,3 cm higher to be on a straight angle with the booster. Hopefully it will hold ...You do not have permission to view this gallery.
This gallery has 2 photos.
What power are you hoping to have at the end off your build fella. We will need lots off photos to keep us in the loop .
- 1 like
New urs6 build
Dear all,
Because i was hiding parts for a while and my wife noticed that the attic became a warehouse i had to hide them somewhere and , where is the best place to hide them than on a car
So, my build looks like this : Woessner pistons, fcp rods, machined head, turbobandit tb60 billet turbo, wagner t3 EM, 1200cc injectors, custom clutch ( 7A flywheel, sachs 707 plate and nissan patrol disc ) , DQT gearbox , garage made fmic, pnp vems and a few more things I forgot for the moment.
This gallery has 5 photos.Tags: None
- 2 likes
