Hoping someone can help with this issue. Changed the fuel filter and on start up I have a fuel leak from where the braided line from filter is joined to the solid line.
I must have stressed the joint when fitting the filter. It is quite loose and I can wiggle it a few millimetres but can't actually pull it off by hand.
So do I try and recrimp the existing clamp or will it need replaced?
Did a search and it seems to be an issue with these cars. I think audi will only sell the braided hose with banjo already attached to the solid line which runs under the car.
Obviously I'd rather avoid doing this and surely there must be a better way. Even if it means getting a different hose made.
Any help much appreciated. I will try and attach a couple of photos later
