Sorry if I have posted this message in the wrong place but I thought it would get the most response here
I have a leaking fuel pipe
The pipe in question is the braided steel fuel hose that comes out of the bottom of the Fuel Filter (fitted with a banjo bolt connector) and attaches to metal fuel line at the bulkhead.
This braided steel fuel hose is crimped onto the bulkhead fuel line and it is this connection that is leaking.
I have a bog standard fuel clamp tightened around the leaking connection and it seems to be stopping the leak but with the Wastegate, Turbo & Exhaust Manifold around this area it is not an ideal solution.
I don't know if the S2 is the same or similar as my S6 but can anybody advise me of a solution on how to go about fixing this fuel leak?
I think the only way to get the pipe off the bulkhead fuel line would be to carefully junior hacksaw the crimped section and maybe get a pipe made locally by someone like Pirtek or similar.
The big question would be how to refit/recrimp the new pipe to the bulkhead fuel line and who would do it etc.......liability issues due to it being a fuel pipe etc.
Or would high pressure rubber fuel injection hose and appropriate clamps be suitable? Maybe not because of the heat issues?
I have the part number of this Braided Pipe as 4A2 201 529C @ £45.00 plus VaT, but the Main Stealer thinks it could be a complete section of fuel line together with the crimped on Braided Steel Hose attached. If this is the case then it looks like maybe a Steering Rack & Gearbox Out job just for a lousy leaking fuel hose!
Any advise gratefully received.
Dave
Dave
