18z caliper brackets
  • Theer
    • Dec 2022
    • 4
    Long time lurker here… I’ve got a 95.5 UrS6 with 18z BBK added by PO. Doing the brakes and the aluminum brackets stripped as I was removing the caliper bolts.
    I found A LOT of threads on the topic, but all are pretty old and links to caliper brackets (Apikol, ECS, Brydon Engineering) all lead to darkness.
    Anyone know where I can find new steel brackets for 18z calipers to UrS4/6 hubs (not Euro HP2 hubs).
    Or can anyone definitively say other 18z brackets (e.g. for a B5 A4 BBK) will work?
    I’d even be happy to find a CAD drawing and have them made locally.
    Thanks!
    Tom
  • struikie
    • May 2019
    • 315
    Can't you have the original alu ones copied in steel?
    JW
    | project | 1993 Audi 80 VR6 turbo quattro |
    | daily | 2018 BMW G31 530d | 345bhp 770Nm |
    • Theer
      • Dec 2022
      • 4
      Yep- that’ll work too- thanks! I was thinking that would be option #3, after buying new/used and CAD machining option. Might end up there.
      • varia
        • 821
        • Current: United States
        or you can do a heli-coil (as it should be).
        you can see it on Alex's bracket: https://cdn.ecommercedns.uk/files/4/...6/img-4843.jpg
        • Theer
          • Dec 2022
          • 4
          Now that’s a good idea- hadn’t thought of that. I’ll try that first.
          thanks!
          • steve briance
            • Aug 2014
            • 1455
            I think i recall Alex saying his brackets use 'timesert' threaded inserts. They are different to helicoil and seem a bit more reliable. Have a read about them and see if you would rather have helicoil or timeserts holding your brakes on.
            threaded inserts threaded, stripped threads, threaded inserts, blown out sparkplugs, stripped threads, stripped out theads, inserts threaded inserts, ford sparkplug repair, threaded insert thread repair spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threaded inserts for stripped threads, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts, striped out threads, threaded inserts, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
            • Theer
              • Dec 2022
              • 4
              Thanks all - I am going to try the Timeserts, which should do nicely to avoid the aluminum-to-steel corrosion which likely caused the problem in the first place.
