1995 UrS6 erratic fuel gauge
  • Jeppy
    • Jun 2023
    • 1
    • Home: United States Current: Georgia
    Hello all,
    From the day that I purchased my s6 the fuel gauge has never properly worked. I thought it was a faulty sending unit but afyer replacing the unit, i am having the same issues. Any insight on fault fuel gauges for the c4 platform?
    • Dec 2017
    • 6006
    If it's like the S2 cluster it could be a dry solder or poor connection. S2 also has a damper relay which can go faulty.
      Or bad connection to the voltage regulator but that usually affects the water temp reading as well.
      When the damper relay was bad on my Avant the gauge would read high, still showed 1/4 tank when the car expired on the M25
