The driveway has a nice circle of oil under the car. I cannot see exactly where the oil is coming from. I suspect front crank seal or the flywheel seal.
Off to my local guy for a wash and inspection. The repairs could end up being expensive.
If the flywheel seal is leaking, then I will most likely replace the flywheel and clutch. Audi South Africa will not supply me the flywheel and LUK do not import the DM flywheel. The flywheel is off the shelf in the UK. Having the S4 in SA and keeping it running is getting to be harder and harder.
