My S4 B7 is at it again. Oil Leak/leaks
  • orsum
    • May 2010
    • 1214
    • Home: United Kingdom Current: South Africa
    The driveway has a nice circle of oil under the car. I cannot see exactly where the oil is coming from. I suspect front crank seal or the flywheel seal.
    Off to my local guy for a wash and inspection. The repairs could end up being expensive.
    If the flywheel seal is leaking, then I will most likely replace the flywheel and clutch. Audi South Africa will not supply me the flywheel and LUK do not import the DM flywheel. The flywheel is off the shelf in the UK. Having the S4 in SA and keeping it running is getting to be harder and harder.
  • Colesy
    • Feb 2009
    • 2983
    For B7 parts Rockauto are far cheaper than UK suppliers for many things. I ordered a fly wheel for the RS4 which was less than half price. I'm not sure if they ship to SA though but worth a look
    • orsum
      • May 2010
      • 1214
      Thanks for the pointer Colesy
      Presently my flywheel is not causing a problem nor is the clutch. While doing the oil seal I thought it would be worthwhile doing the flywheel clutch job. Hope I am doing the right thing.
      Should I just do the oil seal and clutch kit and don't do the flywheel?
      • orsum
        • May 2010
        • 1214
        Yesterday I took my car in for oil leak repairs.
        5ltr of oil per 60km trip. I think this is an oil cooler issue.
        The car is in for
        Stop all fluid leaking
        Replace front and rear crank seals
        Replacement clutch. not slipping just the right thing to do when changing the seal
        Belt tensioner kit replace.
        Check the alternator performance. Replace regulator if needed. no issues at present car has done 300 000km.
        • JayCab
          • Mar 2025
          • 196
          Do you have a fourth pedal to activate the anti-highwayman flamethrowers?
          • orsum
            • May 2010
            • 1214
            The fourth pedal activates the James Bond smoke screen
            • orsum
              • May 2010
              • 1214
              Update
              Oil cooler seals replaced, front crank seal replaced, tensioner kit fitted and a new belt. Filled the aircon gas. No more oil leaks on the front
