I've recently picked up a new daily and it's paint is a little flat. I'm going to machine polish it with my Meguiars G220 dual action polisher but was wondering if I would be best to avoid the pinstripe that runs down each side of the car. Will the polisher take it right off? Or will I just be able to batter over it no problems at all?
canyt really make the pic out, but i'd say avoid, if its been laquered over it will most definately burn through, and if its not laquered you risk pulling the stripe off, thats just from my own experiances though, someone else may have had better results
My guess is that any interaction could recult in it being rather past its best. Better off removing it and then re-applying if you need it on there, pin-stripes are a little old skool but then that could be why you need it, BM? Get some 'pina stripes
you could try putting a little bit of product/polish on a bit of the pin stripe and see if it
cling/sticks to the edges, that'll tell you whether its been lacquered over or not, if it's not you'l get the product sticking to the edges with/without a polisher, and you'll never get the stuff out without removing the stripes, remove with heatgun/hairdryer if you're gonna do it and a wee bit of tar/glue remove to clear the outlines...
another thing to watch out for is pinstripes often get fitted to hide hard lines when panels have been painted, pull it off and your car may be 2 different colours lol
I went over the stripes on the bonnet of my mums mini with no problems, just dont go silly, which you shouldnt do anyway as its very near an edge.
The other option would be to cover it with some blue masking tape, but that could be a bit too wide.
Personally I wouldnt worry too much about it
I agree with Dest. If you go steady there is now way the stripes will come off (unless they are loose already). Take it steady and try a test spot, but you should be fine...
The Perfectionist
I think you would be better of with a lambs wool mop as opposed to a foam pad. The lambs wool will cut quicker but generate less heat and you dont want any heat as it will loosen the adhesion on the strips...
thats why he's hiding the picture defecting to the fast lane of the motorways. Nice car tho
I've already removed the indicator stalk as I won't be requiring that anymore
Originally posted by DJones
Not sure what you are using... but....
Yeah, I've just got foam pads here, thanks for the wool mop tip, I'll have a quick check in town tomorrow morning to see if I can get one (might be limited, being up in Inverness just now though).
